#51 |
![]() Join Date: Oct 2010
Re: Should I leave the Fuel Tank in the Cab?
As a Deputy Sheriff I have never seen one of the in cab tanks blow but I have been to several accidents that involved tanks mounted under vehicles blowing when rear ended. In my experience odds are you will blow up much quicker if rear ended this is why ford has put an fire suppression system in our patrol cars because of the risk of the tanks blowing when rear ended.
#52 | |
It all boils down to personal preference. If you feel safer with the tank out of the cab, then take it out. GM put the tank in the cab because it was the least expensive place for them to put it from a cost of installation on the assembly line perspective. Just think about it: Long bed, short bed, step-side, fleetside, didn't matter, all the tanks were in the cab... it was easy and made them more money due to minimized labor to install. There was very little emphasis on "safety" when designing cars and trucks before the mid 1960's. In 1967 the National Highway Traffic Safety Administration (NHTSA) introduced the Federal Motor Vehicle Safety Standard (FMVSS) No. 301, “Fuel System Integrity” [NHTSA Part 571.301] to reduce deaths and injuries occurring from fires. Initially the standard only applied to passenger cars, however, in 1977 light trucks were also included. GM no doubt saw this standard lurking on the horizon and redesigned the fuel tanks outside the passenger compartment. As far as GM's Safety vs. profit record they actually did a study on this subject in 1973: At the heart of GM's resistance to improving the safety of its fuel systems was a cost benefit analysis done by Edward Ivey which concluded that it was not cost effective for GM to spend more than $2.20 per vehicle to prevent a fire death. While this was certainly done in response to the side mounted tanks that were used on the "new" 1973 models, it shows that safety wasn't job one at GM, profit was. |
#53 |
Vintage 4x4s
Why wouldn't you get more leg room by removing the tank in the cab? You may have to modify the seat mounts but you could push them further back, right?
How many gallons is that Camaro tank?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
#54 |
relocated tanks in all three of my trucks. just personal preference. Agree with the sheriff on being hit from the rear would be more common than a roll over. I just like the clean lines of our cabs. I have early classic tanks in my trucks and they work excellent. cheers, Pat
#55 |
Just for perspective, the 73-87 side tanks are also considered unsafe. So in the cab, in the back, and on the side are all unsafe.
Where should the tank be? |
#56 |
Moderator
![]() Join Date: May 2007
The top of the seat already sits up against the back of the cab with the tank there. Removing it will not gain you any leg room.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 12-28-2010 at 08:35 PM. |
#57 |
Moderator
6 to 1, half a dozen, or the other. It does not matter.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
#58 |
mine is still in cab & no gas smell
#59 | |
Unfortunately that is tough to do, especially on "truck arm" suspensions like ours. |
#60 |
Vintage 4x4s
And with the narrow frames on these trucks. I dont think one from a newer silverado would fit even with leaf springs. Since at least the 99 (and probably even earlier) trucks had a wider frame rail spacing. Maybe someone could find narrow tanks and put one on each side of the driveshaft.
#61 |
Got it laying in the bed in the back. (covered bed)
1970 Chevrolet C-10 w/355sbc ![]() 2010 Silverado Daily Driver ![]() 1971 Mercedes 280sl project car
#62 |
Here is first hand testimony from one of the members here in regards to in cab tank safety. It is from “junkyardjohn”, post #25 on this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=117123
IN 1977 I WAS HIT BROADSIDE AT AN INTERSECTION BY A DRUNK DRIVER (I WAS DOING 55 OR 60) CAUSING ME TO ROLL END OVER END IN MY 72 3/4 TON FORD. AFTER ROLLING ABOUT 80 YARDS, I STOPPED WITH THE TRUCK UPSIDE DOWN WITH MY HEAD PINNED TO THE GROUND. IT STOPPED IN A LITTLE DEPRESSION IN THE GROUND, & EVERYTHING WAS FROZEN(IT WAS DEC. 23rd IN MICHIGAN). THE BEHIND THE SEAT TANK WAS JUST FILLED. IT SPLIT, & ALL OF THE GAS DUMPED OUT OVER ME, & ALMOST DROWED ME IN GASOLINE, AS MY HEAD WAS PINNED TO THE GROUND. I WAS PINNED IN THE WRECKAGE FOR ABOUT 20 MINUTES, I HAD PLENTY OF TIME TO PONDER THE PLACEMENT OF SUCH A FUEL TANK. THE ONLY REASON IT DIDN'T CATCH FIRE WAS MY BATTERY WAS THROWN OUT DURING ONE OF THE ROLLS. LUCKY ME-- I GOT OUT OF IT WITH A BROKEN BACK, 14 BROKEN RIBS, A BROKEN COLLAR BONE & ABOUT 300 STITCHES ON MY MELLON. SO YEAH .... IT IS KINDA A SAFETY THING. Last edited by lakeroadster; 12-29-2010 at 11:15 AM. |
#63 |
I put it behind the seat, but now the seat won't go back far enough for me to get in the truck.........
J/K I'm going to just throw it in the bed! Last edited by ls1nova71; 12-29-2010 at 01:19 PM. |
#64 |
![]() Join Date: Apr 2004
I bought a fuel cell to put between the frame rails of my sons 67. I didn't like the idea of the fuel neck sticking out in case of a roll over. I was thinking more of my sons safety than where he was going to carry his spare. I couldn't think of any other way to eliminate that hazard without relocating the tank. I never got it installed and he had to sell his truck. Here is the setup I have. http://67-72chevytrucks.com/vboard/s...d.php?t=430864
#65 |
it's amazing that some of you guys move the tank in the back for safety concerns.
What about no airbags? abs? full shoulder belts?...etc...etc.etc |
#66 |
I agree. Shoulder belt is a must have, along with better braking.
#67 | |
Cruzin
![]() Quote:
worry less, cruise more ![]()
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
#68 |
Petroleum User
#69 |
I just installed a new tank in my truck back in the cab ,no smell ,no problems .
#70 |
I built it
i moved mine and never gave the cab tank a second thought. i hated that thing, every time i turned right fuel would dump out. with 3 new caps.. it smelled like a gas station.. and i couldnt fill it up much. get maybe 50-60 miles out of it before i had to refill the little bit that wouldnt spill out.. got a new blazer tank and LOVE it.. got 2 vent lines and it fills full speed. and with my truck as top heavy as it is i didnt want to roll over on that cab tank if i get in a crash.
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
#71 | ||
#72 |
just had mine moved under the bed. just knowing I'm not cruising with with my family with our backs against a tank of fuel makes me feel better...
#73 |
Putting the tank behind the seat was dumb...sloshy,smelly and potentially deadly. Is it any wonder GM doesn't do it any longer?
Some reasons to justify spending some cash to move the tank... 1) decent subwoofer/ storage space 2) EFI upgrade possible 3) can shave ugly filler neck 4) moves weight over the rear tires
71 GMC 1500 LWB |
#74 |
Retired Air Force Veteran
![]() Join Date: Aug 2007
I had no reason to change it. Kept the classic look, although, I changed the hard line and I used steel braided hose. I had the connection about 2 feet past the fuel pump and used a 3/8" npt to -6AN Fitting (male to male fitting). I used 3/8" hard line from AutoZone. Be sure to use a small piece of rubber line to transition the hard line from the frame to the cab as there maybe movement between the two (Thanks Wes from Classic Heartbeat for telling me that). Here's a few pics of what I did.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors Last edited by myoldchevytruck; 01-04-2011 at 12:08 PM. |
#75 | |
Petroleum User
| Bookmarks |
