#51 |
Re: How many 4wd Suburban guys do we have?
My heres my 1988 Suburban 3/4ton Silverado..6"lift 35s ectect..
![]() ![]() ![]() ![]() ![]() -getting a lot of work soon, it has a stock drivetrain 350TBI/TH400 with NP-208 and 14 Bolt with 10 bolt front. the plan is a Dana60 front with crossover steering a dual transfercase kit, LQ9 Motor with head/cam E85 and a magnacharger and a built 4L80E with stall from Monster transmissions. custom bumpers with winches, fogs, air lockers, 91 front clip, snorkle and more. Last edited by coreys88burban; 11-29-2010 at 12:56 AM. |
#52 |
I came across these pics of my '91:
#53 |
alrighty then,
since this summer of 2010 this is our daily ride here in the Netherlands. We love it!
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
#54 |
Here's mine...
She's a stock 1985 K10, 6.2L diesel, 3.73 rear end, sitting on 31x10.5 A/T's ![]()
1985 Suburban K10 Silverado 6.2 diesel - receiving some much needed TLC. |
#55 |
Our burb
![]() ![]() ![]() 88 TBI 350 Th400 2.5" lift 285/75 16's Cooper STT 10 bolt front and 14bolt SF rear with lock right locker and 3.73 gears. Soon to have 350 with a little more trimming! |
#56 |
mine is 4X4. Just got it about a month ago. Traded my CJ7 renegade for it and got a little cash to make up the difference. It's a 6.2L diesel with the banks sidewinder turbo installed by the dealership when it was new. Unfortunately I moved from michigan to tennessee a couple years ago and we don't get much snow down here.
91 BURBAN 5/4 TON 6.2L BANKS SIDEWINDER TURBO DIESEL 6" ALCAN SPRING LIFT 14 BOLT FF REAR DETROIT LOCKED 4.56'S DANA 60 FRONT 4.56'S CROSSOVER STEERING WITH HYDRO ASSIST BLAZEN FRONT BUMPER WITH 12K WARN WINCH CUSTOM MADE REAR BUMPER WITH SWING AWAY TIRE CARRIER 37" BFG KM2'S TOM WOODS CUSTOM DRIVESHAFTS |
#57 |
Cool burbs!!
I want one!! Posted via Mobile Device
#58 |
Hootis is as Hootis does...
My 1990 2500 -
![]() 2009 - ![]()
67 C10 LWB Fleet, 383, TH400, PS, 4BL-Holley, Headers & 3" Exhaust, 3" drop front, 4" rear springs, ECI shock relocate, Panhard Bar kit, wheels & tires 1995 Z28 Convertible - Borla, K&N, Lingenfelter Motor, C6 Wheels & Tires 1990 2500 4x4 Suburban 3" Catbac System, K&N, 2" Lift, Wheels, Tires |
#59 |
I didn't see any Burbs on tons......
#60 |
My first.. 83 K20 350/700/208 10boltFront-9.25 rear 3.73
When I got it in 97 ![]() When I sold it in 99 4" 33's- 10.5 to 1 454ci .40over,comp extreme 4x4 cam, rectangle port heads, 750DP. ![]() |
#61 |
My "new" Burb
As I bought it.. 305 2bbl, Sm465,np205, 10bolt, manual hubs,14bff, 4.10's, Non A/C truck $700 ![]() |
#62 |
My daily driving 91 3/4t before i swapped in the d60 then got the wobble of death and now he just sits in the driveway looking sad
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC LB DRW - Sold 2003 1500 Silverado - Selling 2004 Ram 3500 5.9 H.O NV56 CC LB DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LB SRW Last edited by Mr. 250r; 07-13-2011 at 05:57 PM. |
#63 |
As she sit's today
350 4bbl, Sm465(New HD clutch),Np205(Twin stick), 2" front springs, shackles off a 91(longer) Burb 2" rear blocks, Dana 60(open diff), 30spline lockouts, 4.10 gears, 14bff rear(gov bomb). ![]() |
#64 |
#65 |
Resident of Here
1983 K15 from my sig. 432K on the chassis. 32K on the engine/trans/t-case. 75K on the rear. On bald 31x10.5R15
1988 V10 from my sig. 146K on the whole thing. On bald 30x9.5R15.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#66 |
Here's my project.
![]() ![]() ![]() ![]() She's came a long way from the day i brought her home. ![]() ![]()
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! ![]() |
#67 | ||
How do you like the banks turbo? You have this and a N/A 6.2 Burb also, right? Is there a big difference in power? Quote:
Yours is KILLER as well! Same question to you; How do you like the banks kit? Posted via Mobile Device
#68 |
Here's my 85 diesel burb....I need to get a better pic tho. It's a little different now, made some changes to the roof rack. Over the next couple months I want to put dual shocks on all 4 corners, replace the 4 bad glow plugs that are stuck in the heads, and get the new solenoids on my winch so I can put that back on.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
#69 | |
I heard of a trick on the glow plugs, I haven't tried it yet but it came from someone who works on tons of the Detroits and has had specific training. Loosen the glow plug and pull it as far as you can by hand. Unplug the fuel cut off solenoid at the front of the engine. Crank the engine over and the compression will blow the glow plug out. Easier than breaking them off and digging out the pieces... I assume it will shoot out like a bullet though, might want some sort of cushion to catch it. Posted via Mobile Device
#70 |
Thanks!!! I've heard about that trick too. I remember someone said it souned like a gun going off and he had to check his shorts afterwards because it startled him so bad.
#71 |
![]() Posted via Mobile Device
#72 |
Here's my Truckillac - '88 Suburban Silverado package, Heavy 1/2 - 4x4
"I just don't think my Suburban Has much to do with climate change, oh woah, Has much to do with climate change and my mind you cannot change..." Tim Hawkins - Free Bird Parody ![]() |
#73 |
1990 suburban with 10" full spring lift and 38/15.5/20 tire's
#74 |
he cvalcore...NICE! but how the hell do you get into your car?
#75 |
you throw one leg up on the floor board and grab the steering wheel i have and have had a few big truck im use to it.
