Old 12-31-2010, 08:45 PM   #1
BamaDave
Tach trouble.(pics)
I finally got the factory tach put in my truck and at idle it is reading 1750 rpm. Surely this can't be right. I did put the filter in the wire from the tach hook up on the HEI to the "tach" hook up on the gauge. I guess the thing is going to have to be rebuilt or refurbished. Can anyone recomend a place to get this done? I hooked the 12v terminal on the tach to a ignition source of +12v. I think this is right. When I rev the motor it goes way outside the tach readings. I would appreciate any help here.
BamaDave is offline   Reply With Quote
Old 12-31-2010, 08:48 PM   #2
3r!c84
Badass
3r!c84's Avatar
Re: Tach trouble.(pics)
what is it at when key on. motor is not running. it should be at 0
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 12-31-2010, 08:51 PM   #3
BamaDave
When I shut engine down the tach usually stays close to where it was idleing, but when I turn the key to start the engine it snaps back to 0.
Old 12-31-2010, 08:52 PM   #4
3r!c84
Badass
3r!c84's Avatar
and when you start it up it jumps up to like 1750 you say
-00 Saturn 5spd
1/4:13:90
Old 12-31-2010, 08:53 PM   #5
BamaDave
I just added a pic where it is showing where it is when I shut down the engine.
Old 12-31-2010, 08:54 PM   #6
BamaDave
yes about 1750 rpm, and moves as I rev it.
Old 12-31-2010, 09:15 PM   #7
BamaDave
anyone?
Old 12-31-2010, 09:27 PM   #8
76stepsidechevy
you sure you have a v8 tach there? that sounds about what a 6cyl tach might read when used with a v8.
76stepsidechevy is offline   Reply With Quote
Old 12-31-2010, 10:10 PM   #9
BamaDave
came out of a 80-82 blazer, did they have v-6's in them?
Old 12-31-2010, 10:31 PM   #10
RandyP
Getting Old; Going Broke
RandyP's Avatar
Just like most trucks from those years, the "standard" engine was a 6 cylinder. It is possible, but I would think if the Blazer had a nice tach cluster setup it would be a nicer truck with a 305 or 350 V8 option. You never know though.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 12-31-2010, 11:55 PM   #11
BamaDave
Surely someone on here knows how to or who can fix this thing.
Old 01-01-2011, 12:43 AM   #12
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Sometimes a simple search is your best solution.
http://67-72chevytrucks.com/vboard/s...d.php?t=433323
Thread mentions a company who is in tune with fixing these tachometers. Does yours say 8cyl or 6cyl on the back?
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 01-01-2011, 12:44 AM   #13
BamaDave
I didn't notice, where would it be?
Old 01-01-2011, 12:54 AM   #14
rayfinseats
you sure you have a v8 tach there? that sounds about what a 6cyl tach might read when used with a v8. X2
I'd look at EBAY for just the tach part. I'd trade you a factory clock for the small fuel gauge...1983 chevy k10
http://cgi.ebay.com/ebaymotors/73-91...item45f7bf3c1e
rayfinseats is offline   Reply With Quote
Old 01-01-2011, 11:16 AM   #15
RandyP
RandyP's Avatar
Coil, ground and 12v, so easy a caveman could do it. Bad thing is though, when a tachometer goes bad, they read higher than normal and the higher the RPM the more off it gets.
Tach's are very easy to test before you go through all the bother to install it permanently.
Old 01-01-2011, 02:12 PM   #16
dswancutt
Have never used these guys, but they advertise that they repair 73-80 GM Truck tachs.
http://www.tachman.com/oldsun.htm
dswancutt is offline   Reply With Quote
Old 01-01-2011, 11:26 PM   #17
joe231
joe231's Avatar
Tachman wants @$300 to fix one of these.
One of my factory tachs were doing the same thing, read very high at idle and would peg when I reved it up.
I do know how to repair it but it involves some delicate soldering.
Let me do some checking and I will get back to you.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 01-01-2011, 11:56 PM   #18
83burban
I started the other thread you guys referenced earlier and have made alot of progress with my research.
Tachman wasn't as nice I had heard when I called him, and I got the overall feeling that he wasn't the guy for my job. I am going with a company called Redline Gauges.
For about 300 they are going to put a VDO tach motor into my existing cluster, reface the gauge with a factory correct font according to my specs for redline and range. They are also going to calibrate the whole thing so that it is accurate.
83burban is offline   Reply With Quote
Old 01-02-2011, 12:38 AM   #19
BamaDave
joe231, let me know what you find out. I am an electrician by trade and can do the soldering very easily.
83burban, I think that company is in or around Jackson, TN right?
