Old 01-02-2011, 12:18 PM   #1
jsw72c10
bed wood
could anybody tell me the dimensions of bed wood for 72 c10 fleetside shortbed .I'm going to cut my own wood. appreciate any help.
jsw72c10 is offline   Reply With Quote
Old 01-02-2011, 12:59 PM   #2
cdowns
cdowns's Avatar
Re: bed wood
if you go to the vendors list on the main page//GMC pauls website has exact dimensions and hole location required
Old 01-02-2011, 01:46 PM   #3
classicchev
classicchev's Avatar
Re: bed wood
http://www.gmcpauls.com/47-72_BedWood_Info.htm
I have done many sets, and a few suggestions.
Do not use the length dimension listed, every truck has been different.
Bevel the end of the wood over the rear cross sill, will fit much better, and when you open the tailgate it will not look so bad.
Prefit all your wood before you finish it, seems like there is always things that have to be adjusted for a mount or pillar corner.
When you finish the wood, make sure you get all sides including inside all the holes that you are going to drill for the bedsides, wood does not like water, it will turn black even under the finish.
Darren
67- 72 Parts collecter
classicchev is offline   Reply With Quote
Old 01-02-2011, 02:38 PM   #4
c1069
c1069's Avatar
Re: bed wood
Darren
classicchev: You know if can I use the same holes measurement on a stepside bed? This is what I found. thanks
c1069 is offline   Reply With Quote
Old 01-02-2011, 04:49 PM   #5
classicchev
Re: bed wood
Same holes...
When you do the wheels tubs, install all he wood the mark then install the tubs and mark them from the inside.. Trim where necessary.
Darren
Old 01-02-2011, 04:52 PM   #6
jsw72c10
Re: bed wood
thanks for all the help.
