Old 06-26-2003, 12:12 AM   #1
71elect
Timing & Dwell ???
As of yet I still don't have a shop manual for my 71 GMC W/ 307 V8. Does any one have the specs for Dwell and Timing. It would sure help out a lot to know where I should be running. It's a 307 V8, 2Barrel rochester, manual choke, non A/C, 3spd manual tranny. Thanks for any help you can give.
Josh
72Chevy swb 4x4
71GMC swb 2x4
71elect is offline   Reply With Quote
Old 06-26-2003, 03:09 AM   #2
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
i have all the 67 manuals and it says for a any v8 28-32* dwell and gap @ .019 with the timing inbetween 2-8. depending on the engine.... what town you live in?
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 06-26-2003, 04:44 AM   #3
GMC Jim
GMC Jim's Avatar
'71 Chev. Service manual has the following specs for 307 V-8 w/ manual trans.:---Centrifigal advance-- (degrees @ RPM) 0 @ 800; 2 @ 1200; 12 and 24 @ 4300. Vacuum advance:-- ) degress @ 8" vac and 20 degrees @ 17" vac. Dwell setting :--31 to 34 degrees. Timing @ idle 4 degrees before top dead center @ 600 RPM (vacuum advance hose disconnected and plugged).
Another GM service manual ( #SD-100 1971-80 Tune Up Specifications ) shows a dwell angle of 29-31 degrees.... The total advance ( cent. & vac.) should be 26 to 34 degrees @ 2000 RPM.
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
Old 06-26-2003, 04:48 AM   #4
GMC Jim
GMC Jim's Avatar
Omissions from prev msg.....Vacumm advance is 0 degress @ 8 inches vac. and the cent advance is 12 @ 2200 RPM..... sorry about the ommisons ( was referring to manual and didn't check my typing!)
Old 06-26-2003, 08:49 AM   #5
tom hand
CCRider
tom hand's Avatar
GM manuals always have low timing specs for manual trans. That just robs gas milage. Run between 8 - 12 degrees timing (what ever the motor will tolerate without "pinging") and 30 degrees dwell.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 06-26-2003, 07:54 PM   #6
71elect
Thanks guys! Was able to set the dwell to 30 degrees, and the timing to 8. Much better.
stelth2002, I'm over here in Twin Falls.
72Chevy swb 4x4
71GMC swb 2x4
