Old 01-03-2011, 11:56 PM   #2051
bubba327
HOW long until spring??
bubba327's Avatar
Re: Daverods project 66
Dave there is tons of info in the FAQ section on disc brake swaps.. I am using 6 lugs on '72 spindle/rotors
When you come to Motorfest in July I can find you some 1/2 ton stuff around here -- Rock On !!!- Bubba
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 01-04-2011, 12:06 AM   #2052
daverod
SSN 706
daverod's Avatar
Ah, I'm thinking I need some different headers also. Mine already almost touch the ground. At 2 1/2 more there won't be much left. You changed your whole cross member. I'm keeping my orginal cross.
daverod is offline   Reply With Quote
Old 01-04-2011, 12:25 AM   #2053
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
The (a) proportioning valve must be installed since there is no valve originally.
In fact, disks require replacement and or re-routing of most of your brake lines.
The early A arms will take the later disk spindals...
In fact, the A arms are the same on half tons from 63 and at least till 73 and I have seen 79 arms bolt right in place of the 63....
NAPA shows the A arm shafts having the same stock number from 63 thru 81.
Doing a brake conversion is 10 times more easy with the availability of a donor truck to pull all the parts from and 10 times cheaper too..
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 01-04-2011, 12:44 AM   #2054
watahyahknow
watahyahknow's Avatar
the donor truck would have all the brakelines and brackets needed too
if you have the space to store it the time to rip them apart and the knowledge of what is worth money theres money to be made out of donortrucks
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 01-04-2011, 03:14 PM   #2055
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
You can use your stock arms and get disc brakes. You will have to replace the ball joints and get either 71-72, or 73-87 spindles. Make sure that the spindle shaft is 1.25" not the 1". Then you will have to use 4x4 rotors, which is 6 lug. Make sure that you replace the drag link as well to the same year that you use.
It's better to use 73-87 stuff since the parts are cheaper.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 01-04-2011, 03:40 PM   #2056
daverod
SSN 706
daverod's Avatar
The kit is starting to sound better. I did use a parts truck to do my 66 disks. Had to buy new calipers and get the rotors turned also new bearings, seals and hoses. Paid 300 for the truck plus the time to take it all apart and clean it. Still thinking about it.
Old 01-04-2011, 06:55 PM   #2057
ruffrida2005
I had a kit from perfromanceonline.com I ended up selling it for $500 shipped
Paul
Old 01-04-2011, 07:17 PM   #2058
Clyde65
Clyde65's Avatar
I would look at ECE and not buy from CPP, I haven't had specific issue with CPP but many on the board has, I saw a recent issue in the review area about them.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-04-2011, 07:51 PM   #2059
daverod
SSN 706
daverod's Avatar
ece?(www.earlyclassic.com) Never mind ,thanks. I check it.
Old 01-05-2011, 12:02 AM   #2060
daverod
SSN 706
daverod's Avatar
Thanks Bubba I knew I saw it somewhere Just took me awhile to find it again. Motorfest You going to enter your truck?
Old 01-05-2011, 12:08 AM   #2061
ruffrida2005
Hey man do you still have the dash that you put the impala dash in? I got guy wanting to buy one!
Paul
Old 01-05-2011, 12:19 AM   #2062
daverod
SSN 706
daverod's Avatar
I cut it up for the metal contours. I have half.
Old 01-05-2011, 12:33 AM   #2063
bubba327
bubba327's Avatar
I may be ready by July .. Northwest Motorfest is a great show Well if the truck is not ready the Chevelle is always ready for a show.
I bought a kit from CPP for a deal.. It was a E-bay auction for the package of 6 lug rotors and GM calipers with stock GM 71-72 spindles. It was a whole bunch less than catalog price..
Now I know some folks have an issue with them, But I decided that i would take a chance. Have bouht several thing with no problems.
Ebay is always supposed to back up the buyer if an issue occurs..
Hows that compressor running ?? Mine would not turn over and smokes the belts in the cold.. I drained the oil and put in 5W30 motor oil just to get things working in the cold!!
HOW LONG TILL SPRING???
Old 01-05-2011, 12:42 AM   #2064
ruffrida2005
do you still have the guage cluster area and glove box area? That's all he needs.
Paul
Old 01-05-2011, 03:28 AM   #2065
watahyahknow
.. Hows that compressor running ?? Mine would not turn over and smokes the belts in the cold.. I drained the oil and put in 5W30 motor oil just to get things working in the cold!!
you might want to warm that storagetank up a little when its that cold , things start to freese once you using the air , its enough to put frostbite on youre tools and hands
it works like a freezer when you compress you release the warmth stored in the gas when you expand the gasses it pulls heat out of its suroundings , theres even been an american submarine once that sunk and imploded during it maiden voyage because of this , the pipes moving the air frose up and they couldnt blow out the balasttanks to surface
Old 01-05-2011, 11:01 AM   #2066
daverod
SSN 706
daverod's Avatar
I think I have the guage area/ box area i'll check at lunch.
Old 01-05-2011, 11:04 AM   #2067
daverod
SSN 706
daverod's Avatar
My compressor is in a heated garage. I keep it about 45 all the time. No problems so far. Your addicted to ebay.
Old 01-05-2011, 03:23 PM   #2068
ruffrida2005
let me know if ya got it so I can let the guy know.
Paul
Old 01-05-2011, 04:34 PM   #2069
daverod
SSN 706
daverod's Avatar
All I got left is this.
First time I ever hung my sled from a tree.The tree and his buddy did'nt make it.
http://s697.photobucket.com/albums/v...idoveredge.mp4
Old 01-06-2011, 12:20 AM   #2070
spudtruck
spudtruck's Avatar
Daverod, I can't believe the work that you have gotten done. Man I'm jelaous of the heated shop. So whats all the crap about Rexburg?: Hey keep up the good work. Your the inspiration man
spudtruck is offline   Reply With Quote
Old 01-06-2011, 12:23 AM   #2071
daverod
SSN 706
daverod's Avatar
Judges up there suck.edit.edit. Did I really say that? oh well.
Old 01-06-2011, 12:25 AM   #2072
spudtruck
spudtruck's Avatar
You are O so right. I had to go before one on a custody case this summer. No Fun!!!
Old 01-06-2011, 12:25 AM   #2073
ruffrida2005
he decided he wants a whole dash now. It's going in a 86 CC truck.
Paul
Old 01-06-2011, 12:28 AM   #2074
daverod
SSN 706
daverod's Avatar
That will be cool.59 impala would be cool er.er.
Old 01-06-2011, 08:06 PM   #2075
daverod
SSN 706
daverod's Avatar
Gotta love life.mi mal
