Old 12-31-2010, 01:01 PM   #1
gregg72340
gregg72340's Avatar
Turbo 350 Gas vs Diesel........Confused!!!!
Hi guys, have read on here a bunch of previous posts about a gas Turbo 350 vs a diesel Turbo 350. So here is my dilemma I have a gas 305 with a Turbo 350 and the trans is shot. I have a diesel parts truck with a 350 Diesel and a Turbo 350 behind hit that has the dual pattern housing on it (BOP and Chevy). Can I use this trans in my gas truck? I Guess basically what mods or adjustments would need to be made to make this shift right behind the gas motor? Also the parts truck is an 81 so would an 81 diesel have a lockup trans in it or would it be just a regular th 350?
My other dilemma is I can get a 79 parts truck that has a good gas th350 in it but would that be a lock up as well or just a regular one? Because the 79 the only thing really good it would have for me is the trans and thats the only reason I would get it as the rest of the truck is a real tired POS.
I have read the other posts n this idea and it just confused the crap out of me on it so hopefully any responses will point me in the right direction
Thanks in advance
Gregg
Just would like the snow to stop so I can actually work on my truck!!!!!!!!!!!
gregg72340 is offline   Reply With Quote
Old 12-31-2010, 02:35 PM   #2
codydubb
codydubb's Avatar
Re: Turbo 350 Gas vs Diesel........Confused!!!!
From what i understand the diesel th350 has a different valve body in it to make it shift correctly with the diesel engine's rpm range, ive seen one matched up to a gas engine in a friends truck and it shifted horribly way too early, you might be able to switch out the valve bodies and it could work but ive never personally seen it done or know what it would take so dont quote me on it.
1985 Chevy C10
350 .60 over iron eagle h-beam rods, sealed power high comp pistons, forged crank, vortec heads, edelbrock performer rpm vortec intake, roller rockers, .488 .510 cam 750 Demon Double Pumper, Longtube headers, Dual Flowmaster exhaust,Dual electric fans, Proform electric water pump. TCI 3500 Stall Converter th350 trans B&M shift kit 10 bolt 3.73 Detroit Locker
codydubb is offline   Reply With Quote
Old 01-05-2011, 01:50 AM   #3
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
The TH350 from the diesel should work just fine; it's the torque converter that controls when the transmission shifts. You'll notice the difference when you pull it apart. Run a diesel engine with a gas TC (if you can even make it work; you'd have to change flywheels too) and it will shift totally wrong. Run a gas engine with a diesel TC and it will give you a lot more low-end power, but no serious difference in top end. I know guys who run diesel TC's because they like the extra low-end power. But the bolt patterns are different on the two TC's; make sure you match the TC with the flywheel.
I know this because I swapped a 6.2 diesel into my pickup with a TH350, and had to get myself a new TC to match the engine. But the trans worked perfectly fine; no wierd shifting at all.
Best way to check if it's a lockup TC is if the trans has an electrical plug on the driver's side. If it does, it's a lockup. If it doesn't, then it's not.
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 01-05-2011, 04:01 PM   #4
gregg72340
gregg72340's Avatar
So I was wrong in assuming that the governer controlled when this shifted?
Old 01-05-2011, 04:41 PM   #5
lindstromjd
Yeah. The internals of a diesel transmission are slightly different, yes, but it's so that they can handle the extra torque of the diesel engine vs the gas; not for when they shift. You shouldn't have any problems by using it.
-357 / 700r4
-350 / TH350
Old 01-05-2011, 05:18 PM   #6
spudz
spudz's Avatar
i think all you need to use a diesel trans in gas is converter and governor. The rest is compatable. If you use diesel governor, the shifts will be to fast. The converter doesnt control when the trans shifts, just the stall speed.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 01-05-2011, 05:19 PM   #7
spudz
spudz's Avatar
no your not wrong.
Old 01-05-2011, 06:26 PM   #8
lindstromjd
I stand corrected.
-357 / 700r4
-350 / TH350
Old 01-05-2011, 07:36 PM   #9
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
The only big difference is the torque convertor. I highly doubt any of the internals are different other than maybe a few more clutches in a drum here or there and maybe the govonor. The valve body is the same, maybe with different springs. But the torque convertor for the diesel is heavier duty as in the stator fins are stronger, and they generally have less stall than a gas convertor. Since it sounds like you're in a pinch, you could use that trans and torque convertor behind your 305 and be fine. The stall speed may not be what you prefer, but it should be drivable.
Ryan
1969 Chevy milk truck
Old 01-05-2011, 08:05 PM   #10
spudz
spudz's Avatar
I agree. Thumpin455 put a diesel 700 in his truck and left it alone.
Old 01-06-2011, 07:37 AM   #11
billnorman
Man, I hope you're right. I have a friend with a diesel suburban with a 700r4 that I could sorely use behind my 4.3 with a 3.70 rear. I better see if i can get it from him before he junks it out.
billnorman is offline   Reply With Quote
Old 01-06-2011, 09:39 AM   #12
spudz
spudz's Avatar
I think the 700 torque converter had different bolt pattern then gas but I think he just drilled it. I dunno, he used to post on here often. maybe pm him
Old 01-06-2011, 03:05 PM   #13
lindstromjd
The torque converter has the same bolt pattern on the flywheel; but it's the input shaft that's different between the 700's and 350's. 350's have 27 teeth, and 700's have 32. Just get a gas torque converter and you should be fine.
-357 / 700r4
-350 / TH350
Old 01-06-2011, 03:48 PM   #14
Dieselwrencher
The biggest difference between a TH350 & TH400 torque converter from a 700R-4, is the 700R-4 has a clutch in it for lock up just like a torque converter for a lock up 350. They are not interchangeable with TH350's & TH400's either.
Ryan
