Old 09-27-2010, 03:14 PM   #1
eyebuzz
Licensed driver
eyebuzz's Avatar
C20 rear brake pads
Hello,
72 Suburban C20 at the shop right now to fix differential leak in/around the brake drum. My mechanic says there are two different brake pads for this axle - depending on the drum - one set is still available and one isn't. In the photo below, anyone see anything unusual about this drum (beyond it's covered in oil)? The drum itself is stamped : May Dia 11.24 - 3998512 - W-3
I suppose the question is - would any commonly available brake pad set fit this (available from LMC etc.)? Before he opens this up he'd like to have the parts on hand.
Thanks, Tim
eyebuzz is offline   Reply With Quote
Old 09-27-2010, 09:36 PM   #2
GMCBubba
GMCBubba's Avatar
Re: C20 rear brake pads
what rear axle do you have? i was able to get the pads from advance, i believe (raybestos) for my 69 c25 with dana 60. it's the crappy drums that were so hard to find ($120 each). should've just converted to disc. ha
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration.
GMCBubba is offline   Reply With Quote
Old 09-28-2010, 03:53 AM   #3
CCCC
CCCC's Avatar
Have never experienced difficulty getting new pads for the 3/4 and 1 ton rears, Eaton or the others. Yes, probably are two (or more) sizes of drums/pads depending on mfr. and year but seems odd that the shop cannot locate replacements. Your leak is almost surely the shaft seal (big one) that sits in the opening of the drum and the dissassembly is not all that difficult or time consuming, and then you can see exactly which pads you need. The seal may be harder to locate than the pads. He may not want to tie up shop space with the axle out while he goes on the search he may think he will have to do. Bummer. If you have space, take it home and do it yourself - guys on her will walk you through the job. Good luck. CCCC
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 09-28-2010, 04:16 AM   #4
RUSHNBOBO
Originally Posted by eyebuzz View Post
Hello,
Thanks, Tim
There are 2 widths both 11", and last time I checked they were both avail through LMC...but i do know 1 is much less common ...probably earlier models with the all ball bearing Eaton.
Take note the more common size is exactly the same as thousands of later model 3/4 ton rears axles the interchangeability is vast ....brake shoes tend to be very generic and they don't change the configuration very often its just everything else around them.
Looks like from the pic that u have a Eaton HO72...same as my 1 ton except i have the 13 inch brakes which are the same shoes as all 14 bolt corporate.
If you have a '72 you should be fine 11 inch brakes for 73-87 are the same for that matter even the front brakes on early trucks 11 inch are also the same....
RUSHNBOBO is offline   Reply With Quote
Old 09-28-2010, 08:46 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the only way to honestly tell what brake shoes are in there (pads are for disks) would be to open it up.
There were more than 2 part numbers.
That looks to be the HE52... not HO72. The 72 was only in one tons.
Old 09-28-2010, 09:58 AM   #6
eyebuzz
Licensed driver
eyebuzz's Avatar
Thanks all...word from a previous post of mine is that the differential is the H052.
Old 09-28-2010, 01:28 PM   #7
RUSHNBOBO
Fact; HO72 and HO52 are very similar, BOTH came in 3/4 ton trucks, the only real differences are the diff carrier, pinion, and its bearing , HO72 has a load bolt which rubs against the ring gear under high load conditions and can easily be seen on the third member as a large bolt/w a lock down nut. this load bolt increases the axle load capacity.
Externally they look nearly identical ..you need to look for the load bolt on the side of the third member ......I've owned two 3/4 ton's one '68 and one '72 and my current '68 1 ton. The '72 3/4 ton had a HO52 and the '68 3/4 ton had the HO72. My '68 1 ton has the same exact third member as the '68 3/4 ton ....HO72..(load bolt). It does have a narrower housing and larger brakes being a dually.
There is another Eaton: HO110 which can be identified by no diff cover, 10 lug wheels and has much larger dimensions. A few 1 ton's came with this diff.
Also checked '63-'70 all 3/4 ton trucks had exactly (2) sizes of brake shoes period, these are the same part for both front and rear, 71-72 rear only....12 x 2 1/2 or 11 5/32 x 2 3/4. If you see different part numbers it has to do with standard or premium shoes. 1 ton's used 13" brakes exclusively.
Check page .....5 .....here's the list of HO52-HO72 breakdown from '64-'72!!!
http://www.stovebolt.com/ubbthreads/...&Number=614721
Old 12-30-2010, 01:36 PM   #8
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
^Thank you for the great post.
I'll be digging into mine soon.
It'd be nice if the OP would post back with an update of how it went.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 12-30-2010, 02:19 PM   #9
cdowns
cdowns's Avatar
as long as the metal shoes are in good servicable condition they can b relined by a company specializing in brake relining
for sources google "brake relining"
Old 12-30-2010, 03:52 PM   #10
eyebuzz
Licensed driver
eyebuzz's Avatar
Actually, never did the job yet - ran out of money - got money - bought parts (drums and shoes, figure I'll return if the wrong size) - temperatures dropped to low 30s - snowed - and they salted the roads (so now the burb is in "storage," i.e. my driveway with a car cover on it) - so now I'm waiting a bit (probably Spring now) to get back into it all. I will post again when I open it up.
Best, TT
Old 12-30-2010, 03:54 PM   #11
eyebuzz
Licensed driver
eyebuzz's Avatar
Cdowns...thanks (and thanks to all who've posted), that's good to know if I've got some odd sized shoes in there. Best, TT
Old 12-30-2010, 04:06 PM   #12
LostMy65
LostMy65's Avatar
Best, TT
I here you there..
We've been in the 40's, but being over 45 years old, it still hurts.
I just bought my 66 in Nov, so I'm still anxious to work on it, and so I'll endure the cold.
Thanks for the update.
Edit:
Yes, Thanks cdowns, that is good to know we still have other options.
Old 12-30-2010, 04:07 PM   #13
RIA69
RIA69's Avatar
I have the same rear end the eaton ho52 and I had no issues getting the pads either size from autozone. they were only like $19 for one size and $14 for the other size. i picked up both for the simple fact that one size is the same as my front brakes and the other may or may not fit if it dont i cann return them. just my .02.
1969 C20 3/4
ΜΟΛΩΝ ΛΑΒΕ
RIA69 is offline   Reply With Quote
Old 12-31-2010, 03:59 PM   #14
swamp rat
swamp rat's Avatar
Subscribed! Great info for us unlucky Eaton owners.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-31-2010, 10:53 PM   #15
RIA69
RIA69's Avatar
here are the auto zone part numbers for duralast pads. the 11 and 5/32 are the front and it may or may not fit the rear as well depending on what size your rear drums are.
Duralast/Brake Shoes - Rear
Part Number:419
Application: With 12 x 2 1/2" brakes
$14.99
Duralast/Brake Shoes - Rear and front
Part Number:450
Application: With 11 5/32 x 2 3/4" brakes
$19.99
each set includes 4 shoes enough for the entire front an/or rear. they have worked pretty good for me so far even though I have only had time to do the front brakes right now. I hope this helps someone.
1969 C20 3/4
ΜΟΛΩΝ ΛΑΒΕ
Old 01-05-2011, 03:00 AM   #16
LostMy65
LostMy65's Avatar
RIA69,
Thanks for the part numbers.
