Old 01-05-2011, 01:02 PM   #1
bmchevy1979
bmchevy1979's Avatar
Is it worth it
Okay on craigslist there is a 1980 Chevy 3/4 ton 4x4 (Federal Truck). Current Non-op. Locking front hubs, 4 speed with granny low, 350 motor, 410 gears.
$900 OBO
do you think it is worth the price for axles, springs and trans and transfer case and other items to go into my blazer. I could probably put what I take out of mine in it to resale as a 1/2 ton 4x4 with auto I talked to the guy and he said it was driven there and someone stole the dizzy so I could probably make run for little of nothing
here is the link
http://visalia.craigslist.org/cto/2103297657.html
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 01-05-2011, 01:57 PM   #2
jbclassix
Junk Yartist
jbclassix's Avatar
Re: Is it worth it
In my opinion, yes. Looking at the front end thought it doesnt look like an 80. 1980 had square headlights. it looks like a 79. It as a service body on it, so you could either sell or scrap the truck and make your money back. I would pull the spark plugs and see how they look. It will probably have a larger radiator than your blazer. In Cali that would be a plus.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 01-05-2011, 02:56 PM   #3
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: Is it worth it
I would say it is just for the parts alone. Offer them $500 take off the stuff you want then scrap the rest. In the end, your parts will probably only cost you $100-$200.
That truck could very well be a 1980. The lower level trucks still had round headlights in 1980.
DirtyLarry is offline   Reply With Quote
Old 01-05-2011, 03:24 PM   #4
MTCK
MTCK's Avatar
Re: Is it worth it
I would say yes. Having a donor vehicle is much nicer than a pile of parts when you are doing a swap like that. You are going to a stronger drivetrain, getting rid of the 203 and getting lower axle gears all at once, plus you'll have all the things like cross members, clutch pedal and parts and drivelines there to use what you want.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 01-06-2011, 12:56 AM   #5
bmchevy1979
Re: Is it worth it
thanks for the replies I was thinking it would be worth it just wanted someone's thoughts on the idea the radiator shouldn't be any bigger because mine has a 400sb which has a big block radiator from the factory
<Brandon>
