Closed Thread
Old 01-06-2011, 02:04 AM   #901
SCOTI
SCOTI's Avatar
Re: Got some new wheels: Boss 338's in 20x10 and 20x8.5
BossHogg, that is freakin' sweet!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is offline
Old 01-06-2011, 02:23 AM   #902
BossHogg69
motor exploder
BossHogg69's Avatar
thank you sir, I've been hanging out in the suspension forum trying to get my 'Pro Tour' on with this truck!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline
Old 01-06-2011, 03:07 AM   #903
lolife99
67-72 parts collector,…
lolife99's Avatar
Originally Posted by scoti View Post
bosshogg, that is freakin' sweet!
x2^^^
Keith
Convert to disc brakes.
lolife99 is offline
Old 01-06-2011, 08:08 AM   #904
piecesparts
Parts and more parts
piecesparts's Avatar
Unless I am blind, this does not apply to the model of trucks, such as my son's 86 Silverado. The 18 X 8" wheel appeared to seat directly onto the front disc brake hub without issue, except the center cap clearance. The 20 X 10" wide rear wheel seats well up against the drum and the backspacing looks good to align with the springs and the inner fenderwells on this year of truck. We seated the front wheel with a 3/16" thin spacer, just to make sure the cap would seat right. I am going to look again, but I thought we covered every angle the first day.
Originally Posted by brossow View Post
The Rev 3 version of this wheel (currently only available in 20") uses a completely different style of center cap that should eliminate this problem. The real issue is that the hub bore is too tight in critical places to allow the wheel to seat against the hub without a spacer (on the front).
In the rear, it depends on which width you get as to whether it will fit (disregarding "looking right") without a spacer. The 10" rim requires 1 1/2" to 1" spacer, depending on application. The 8" rim may fit fine without a spacer; I have no experience with this width and its accompanying backspacing.
Frank
piecesparts is offline
Old 01-06-2011, 09:35 AM   #905
bcutt
bcutt's Avatar
Originally Posted by BossHogg69 View Post
Gonna start with a 4.5/6 for now (I have CPP 2.5" spindles and 2" springs, with 6" springs and a c-notch out back, but I imagine I'll end up adjusting it a bit to get the fenders right above the tops of the tires. The back tires are about a half inch taller than the fronts, as I like a little bit of 'rubber rake' on my dropped trucks. I may go an additional .5" f/r to make it 5/6.5, but I'll only know for sure after I get the engine back in and the body on it. I do know that those 335's will be screaming for mercy when I unleash my aluminum headed solid roller 468" BBC and the TKO 5 spd on them! Here's another pick of it out in the light.
Thanks for all the details. I hear ya about the 468, I'm thinking of spending the $$$ where it counts and going with something like this
"Some of my finest hours have been spent on my back veranda, smoking hemp and observing as far as my eye can see."
- Thomas Jefferson
72 C10 SWB "Work in Progress"
bcutt is offline
Old 01-06-2011, 09:53 AM   #906
mcbassin
Still Learning
mcbassin's Avatar
You may have the 1" wide front rotors up front. This would allow your wheels to fit flush with the rotor without having to machine them. As for the 10" backspacing I don't know.
mcbassin is offline
Old 01-06-2011, 04:15 PM   #907
spazzyfry123
spazzyfry123's Avatar
So a quick recap... Looking at these wheels in 20x8.5 and 20x10 for my '68 SWB Fleetside with a 12 bolt rear with drums/'87 front with discs with a 5 on 5" bolt pattern.
I am unsure if the set up is with a 1" or 1.25" thick rotor, but if it is 1" everything should work just fine up front? It is dropped ~5" with spindles and springs up front as seen here...
But if they are the 1.25" thick rotors, then I will need to change out rotors, calipers, spindles, balljoints, etc. just to get the wheels to fit up front...? Or shave down the "dust cap" area on the rotor every time?
Sorry if it has been mentioned before, it's just after reading through a billion pages about "new style" 338s, 1" this, 1.25" that... My brain just got a little fried.
Thanks,
-Tyler
spazzyfry123 is offline
Old 01-06-2011, 04:31 PM   #908
brossow
Amateur Rust Fighter
brossow's Avatar
Thanks,
-Tyler
Out back, your offset will be way wrong and you'll need spacers (adapters) in the neighborhood of 1" to 1.5". The '68 rearend is considerably narrower than the '88-up these were designed for.
Up front, you can (1) use 1/4" spacers (which will push the wheels too far out to look "right"), (2) machine down the hubs (exact dimensions are provided with a mechanical drawing elsewhere in this thread, probably somewhere in the last 10 pages or so), or (3) swap in light-duty (1") rotors, which will also require different spindles, calipers and anything else associated with that downgrade.
You sure you don't want to consider something else that's designed to fit? Would probably be less expensive when you add it all up and would definitely be a lot easier.
Brent
'72 Chevy SWB stepside - [ Build Thread ]
'79 ChevMC SWB fleetside - [ Build Thread ]
'64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...)
brossow is offline
Old 01-06-2011, 04:48 PM   #909
ARTISTIC
I really like the style of these wheels, they look great on what rides have managed to accomodate them and Ive read through all 37 pages of posts but curious what the big difference between the Boss 338 and AR Torq Thrust II's or the AR Torq Thrust C100's?
Is cost the biggest deciding factor since they look very similar?
ARTISTIC is offline
Old 01-06-2011, 04:50 PM   #910
brossow
brossow's Avatar
Cost is one factor. Being different is another -- there are a bajillion TT2's on the road.
Brent
brossow is offline
Old 01-06-2011, 04:55 PM   #911
lolife99
lolife99's Avatar
Cost is why most want these wheels.
I bought all 4 of my 20" 338's for a little less than $700.
20" Torque Thrust IIs' are between $450-$500 each.
Keith
lolife99 is offline
Old 01-06-2011, 04:59 PM   #912
mcbassin
Still Learning
mcbassin's Avatar
In case you want to go the route I have gone HERE is a link to the pdf files of the mods I did to the 1.25" rotors. You can tell by the pic the rear is set in about 1"-1.5 too far. The wheels look great though and they were cheap (i have access to machines) compared to Coys and TT2s. Good luck!
mcbassin is offline
Old 01-06-2011, 06:13 PM   #913
brossow
brossow's Avatar
Bingo! Thanks, Mike -- that's the one I was talking about. Forgot who had posted it and when.
Brent
brossow is offline
Old 01-06-2011, 07:32 PM   #914
spazzyfry123
Thanks for the help! The big reason I was drawn to these wheels is that it is more of a modern take on the classic design.
Now if there's something out there that's similar but actually fits, speak to me! I really like the grey-centers... Not big into either chrome or glossy centers. Also if it makes any difference, the truck is tubbed in the rear.
Thanks,
-Tyler
Old 01-06-2011, 08:05 PM   #915
69C-owner
Here is my question, my truck is going to be a resto-mod, nowhere near fully stock, I plan to put big drilled and slotted rotors and six piston calipers on my truck, I havnt decided on a paticular set yet but I really like these 338's and I want to know if anyone knows a good brake setup to use without modifying anything, I'm also thinking about using airbag suspension, so with aftermarket brakes air bag suspension and maybe spacers what is my cheapest and easiest way to use these wheels, im not like hellbent on these so if it comes right down to it i might just get some really nice TT's and save money on brakes and suspension, any advice?
http://67-72chevytrucks.com/vboard/s...d.php?t=43855069 LWB Fleet
1994 Buick Roadmaster
1994 GMC Sonoma
69C-owner is offline
Old 01-06-2011, 08:12 PM   #916
mrhino
just machine down the hubs on the 1.25 rotors like mike said, and glue the dust cap on and your good to go. its not that hard. no spacers either. I converted mine to rear disc maybe thats why didn't need spacers.
mrhino is offline
Old 01-06-2011, 08:24 PM   #917
69C-owner
Ok well the question now is machine it how how and does taking away that material weaken the hub?
1994 GMC Sonoma
Old 01-06-2011, 08:30 PM   #918
mrhino
I had a local machine shop do it. Is it weaker than it was? sure, but theres still plenty of material there. if it ever fails, it wont be because of that.
mrhino is offline
Old 01-06-2011, 08:45 PM   #919
69C-owner
Thanks for the info, Do you remember the measurements on how much they took off and how far they went in toward the hub? Im wondering if anyone makes a rotor that is thin enough, I wont be buying the wheels or brakes for a long while so if I can buy a certain brand of brakes I'll save the money up and have my eye on what I need, if I'm wrong correct me but it looks like you've done your conversion with stock replacement parts, I plan on puttin 5 years of work into my truck at least so if i drive around on stock steel wheels for the next 7 years thats no big deal to me lol
1994 GMC Sonoma
Old 01-06-2011, 08:46 PM   #920
mcbassin
Still Learning
mcbassin's Avatar
I turned them back on the manual lathe. I have a fixture I made I could send you if you need it. Just send it back to me when your done.
Weaken the hub? I don't think so. I can have my mechanical engineer friends do some calculations but I be the answer is going to be no, not enough to matter. Take a look at your rotor, it's pretty beefy.
mcbassin is offline
Old 01-06-2011, 08:50 PM   #921
mcbassin
Still Learning
mcbassin's Avatar
I made a drawing of the mods I made. There is a link above about five posts. pdf format.
mcbassin is offline
Old 01-06-2011, 08:51 PM   #922
piecesparts
We do not have the 1" front hubs. They are the 1.25 brakes and believe me, the wheel fits right onto the hub and seats up against the flat surface that the bolts are mounted. The deal that we noted was the dust cap on the center hob pushed the center cap on the wheel out about 3/16". We did not have to force it, in any way shape or form. This whole discussion kind of confuses me, so far. Been turning wrenches for a few years, too. Need to go look some more.
Frank
Old 01-06-2011, 08:53 PM   #923
69C-owner
Thank you for the offer Mike, I just might need that fixture but no time soon, i'll deffinatly let you know later on if i need it.
1994 GMC Sonoma
Old 01-06-2011, 09:08 PM   #924
spazzyfry123
I would be interested in hearing more about this!
Old 01-06-2011, 09:22 PM   #925
mcbassin
Still Learning
mcbassin's Avatar
Frank,
I trust you know what rotors you have. I wonder which revision of wheels you have? Mine were made early last year, I think around Jan.-Feb.? I would like to know what is different about yours? I'm thinking about getting another set, the gray center this time. It would be cool if they would just bolt on.
mcbassin is offline
Closed Thread
