Old 01-06-2011, 04:36 PM   #1
baradonai
Angry when did GM put catalytic converters on Sierra 305s?
I bought my 1977 GMC Sierra with a 305 from a guy in Alabama about 4-5 years ago. Other than change oil,plugs, wires and brakes it's just the way I found it. i've passed emissions every year...except this year. All of a sudden they tell me it's missing the catalytic converters. I'm suspicious. Did these trucks even have cats? LMC doesn't list them in their parts. The two doofuses in the testing facility looked like couldn't make change from a twenty without a compter. Fumbled all over the truck looking for numbers, couldn't open the hood without my help. Frankly, I think I'm being railroaded.
baradonai is offline   Reply With Quote
Old 01-06-2011, 04:40 PM   #2
baradonai
Re: when did GM put catalytic converters on Sierra 305s?
I'm in middle Tennessee, by the way.
Old 01-06-2011, 04:57 PM   #3
Old Money
if GVWis 6000 lbs. or less you need a cat..
Old Money is offline   Reply With Quote
Old 01-06-2011, 05:07 PM   #4
355bullet
355bullet's Avatar
damm, tn is rough on emissions
found a link
http://www.tn.gov/environment/apc/vehicle/
355bullet is offline   Reply With Quote
Old 01-06-2011, 05:12 PM   #5
lakeroadster
I believe 1975 was the first year that they were required on 1/2 ton trucks.
lakeroadster is offline   Reply With Quote
Old 01-06-2011, 05:15 PM   #6
Keith Seymore
Keith Seymore's Avatar
I can confirm our '75 1/2 ton shortbox had a cat converter.
(It blew up and tossed it's contents all over the freeway).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-06-2011, 06:00 PM   #7
Greenlee
Greenlee's Avatar
Is the truck a Big 10 or Heavy Half? My 76' didn't have cats because it was a Big 10. The whole reason behind the Big 10's and Heavy Half's was to get around emissions standards as I understand it.
Greenlee is offline   Reply With Quote
Old 01-06-2011, 07:31 PM   #8
baradonai
Thanks! Door tag says GVWR is 4900 so I guess I do. Just floors me that I've been passing inspection all these years (at two locations, mind you) with nobody saying anything.
Just aggrivating because I've got another vehicle in the shop already and I'm not all that fired up about paying the extra money right now.
Old 01-06-2011, 08:07 PM   #9
68longhorn
68longhorn's Avatar
Did it fail because of visual inspection. If so go to a junkyard, get a old one of a car, cut it open(top half/bottom half), wrap it around the pipe and weld it back on.
68longhorn is offline   Reply With Quote
Old 01-06-2011, 09:04 PM   #10
baradonai
It started at about 2500 hydrocarbon with 500 being the limit. I put some seafoam and alcohol in some premium gas and gunned it to the next town down the innerstate. Figured this would do it. Imagine my surprise when I was told I was short a catalytic converter only two days after I was told that it was simply high on hydrocarbons!
Old 01-06-2011, 10:28 PM   #11
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
was it one place that said you needed a converter? If so you might want to try another place that know what they are doing before you go through the trouble of getting a cat..
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 01-06-2011, 10:39 PM   #12
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Don't feel like your alone...had some doofuss try to tell me the same for my '68! I had to laugh at the whole shop...as non of them knew it was 1975 models (for some '74) when things changed and regular leaded fuel was on its way out and unleaded was getting its start. Yes, from 1975 to 1980 there were both 1/2 tons and 5/8 tons (Big 10 and Heavy Half) sold. 1/2 tons had all the smog stuff....the 5/8 tons got HD hardware and no emissions.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-09-2011, 10:18 PM   #13
bmchevy1979
bmchevy1979's Avatar
This may help http://73-87.com/7387info/7387emislevel.htm
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
