Re: What did you do to your truck today!
Started it and let it run a while. Haven't done that in a while since it turned cold. Everything worked fine too!
-Scott- Last edited by sjarrett71; 01-09-2011 at 10:40 PM. |
Cruzin
installed my new clutch fan week ago in place of the flex fan haven't drove it yet because the yard is too muddy from the snow and rain (had to lock my 4wheel drive in on my 86 to get it out of the back yard and suppost to snow 4-8 inchs tonight and tomm. So it might not move till spring and i live in the south!
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
Sprayed oven cleaner on some more parts, washed it off and finally found a little rust...not to worry, it's low on the pass side front fender well and only superficial. California truck.
Posted via Mobile Device |
Changed out all the cab & core support mounts on my 72/3/4 ton project. pulled the grille, realigned the doors& front clip pics to follow. cheers, Pat
