Closed Thread
Old 01-07-2011, 09:19 PM   #2351
towersddg9
towersddg9's Avatar
Re: What did you do to your truck today?
Picked up cross member and control arms powder coating makes those 45 year old parts look new again, frame going next week getting it done in a flat
towersddg9 is offline
Old 01-07-2011, 10:27 PM   #2352
daverod
SSN 706
daverod's Avatar
Those parts look sweet.
daverod is offline
Old 01-08-2011, 12:35 AM   #2353
markeb01
Senior Enthusiast
markeb01's Avatar
Those are beautiful! Certainly way better than how they looked when new.
markeb01 is offline
Old 01-08-2011, 02:31 AM   #2354
BigPhil66
BigPhil66's Avatar
Those look great!!! I hope mine look half as good as yours when I am done. Now I am considering doing the cross member...thnks a lot! : )
BigPhil66 is offline
Old 01-08-2011, 07:53 AM   #2355
wlevick
Completed the bed wood kit for my '65 Fleetside (oak). I sanded them with 100, then 220, then five coats of Minwax Helmsman (sanding between coats with 220). Then I water sanded them with 1500, then 2500 and then buffed them out. They look awesome...if I must say so myself. Pictures to follow.
wlevick is offline
Old 01-08-2011, 10:29 AM   #2356
towersddg9
towersddg9's Avatar
$187 bucks that includes sandblasting, you will save money if you clean all that crud off I scrapped gue off for a good day
Old 01-08-2011, 01:07 PM   #2357
jbgroby
jbgroby's Avatar
Picked up the seat from the shop this morning, The small lines/wrinkles at the top will fade out after she been used a bit.
I'll post some pictures of the new 'bolter on the seat later.
The tan seat was the '39 DeSota he's finishing up, SWEET.
jbgroby is offline
Old 01-08-2011, 02:20 PM   #2358
jbgroby
jbgroby's Avatar
Newest Member!
Grandson Ethan!
jbgroby is offline
Old 01-08-2011, 02:46 PM   #2359
markeb01
Senior Enthusiast
markeb01's Avatar
That seat turned out beautiful. Your grandson seems a bit confused by it though! Always loved the 39 Dodge and DeSoto body style. Real art deco. From what can be seen it looks fantastic.
markeb01 is offline
Old 01-08-2011, 06:35 PM   #2360
lakeroadster
More progress on the dash. Installed gauge panels.
lakeroadster is offline
Old 01-08-2011, 08:31 PM   #2361
Cobblemizer
Tore the steering column apart on my 63, welded up the inner shaft (deep grooves from no bearings in the column) then sand blasted the outer shell and repainted it satin black. Now searching for a steering wheel.
Cobblemizer is offline
Old 01-08-2011, 10:06 PM   #2362
k1rodeoboater
Reinstalled my rear bumper and mounted up my new carb. I still have to tune it for a/f and idle, that will be tomorrow morning. Im also going to get the bench out of a 69 GMC tomorrow and installing it. The seat will be free, Im selling my buckets in my truck for $20 which is what the bench costs. I also need to rewire my tail lights
k1rodeoboater is offline
Old 01-08-2011, 11:30 PM   #2363
towersddg9
towersddg9's Avatar
Pulled bed and bed wood today, will drop the frame off for some sandblasting and powder coating next week
Old 01-09-2011, 12:41 AM   #2364
Vernski
Lakeroadster I like the Camero dash and hood scoops. Are you putting a wood cap on the dash or a padding strip? It will look cool either way...Vernski
Vernski is offline
Old 01-09-2011, 04:53 AM   #2365
old cruiser
old cruiser's Avatar
Took 64 to rod run in Port Fairy about 200 klms round trip plenty of nice cars there , the pickup ran a treat , now to sort getting rego.
old cruiser is offline
Old 01-09-2011, 08:38 AM   #2366
lakeroadster
Originally Posted by Vernski View Post
Lakeroadster I like the Camaro dash and hood scoops. Are you putting a wood cap on the dash or a padding strip? It will look cool either way...Vernski
Thanks Vernski. The plan is to make a wooden cap that screws to the dash and then put vinyl over the wood. This makes a dash pad that looks similar to factory ones that were used.
Old 01-09-2011, 10:35 PM   #2367
64GMCHorsepower
Justified!
Had ordered a new top end kit to install. Was going to do most of it in with the eingine in the truck. My Dad came over to help.
Well, ended up pulling the front clip, and the motor, and am in the process of installing a new top end kit....
Clean/paint engine and front frame rails....
oh, and have to have it done by Tuesday afternoon when my wife gets back.....
so I have a block with new cam/ getting ready to paint, then install heads, and intake, the put everything back together....
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline
Old 01-10-2011, 02:59 AM   #2368
198plus
198plus's Avatar
That dash is really turning out nice !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
198plus is offline
Old 01-10-2011, 12:35 PM   #2369
tenni126
My buddy and I got to work on the disc swap this weekend, and completed it just in time for dinner last night. Wife was a little peeved, as I told her it'd be a day, day and a half tops. Oops. If it wasn't for all the runs to the parts store, I'd have made it. Got it done though, at least the front. Back discs will have to wait until I can re-drill the axles for the 5x5 pattern. The difference in braking is...amazing. You press the pedal and it just stops!! I think my truck just made it to the mid 70's in braking tecnology
The CPP kit is pretty top shelf. Had to make new lines for the front (to separate the front and back circuits) and still have to drill the firewall for another couple mount bolts, but otherwise everything was bolt-on, particularly the spindles and disc setup. Good times. Also threw in the ECE drop springs, so with the 2 1/2 drop spindles I am now at 4 1/2" total drop in the front and 4" in the back, with what I think is just the right amount of rake.
tenni126 is offline
Old 01-10-2011, 11:18 PM   #2370
Rich 5150 69
Rich 5150 69's Avatar
Nothing exciting like a blower install just new brakes shoes, can anybody tell me where I can get decent brake shoes, the last set I had on my truck were heat checked bad, rivited but started falling apart, this set I replaced Sunday one side linning had separated from the shoe itself, ( glued not rivited) thats what prompted this brake job was the unusual noise while stopping. First set from Napa, second set from autozone.......new set from napa again.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline
Old 01-11-2011, 03:13 AM   #2371
tapeworm
fan of "Butters" Stotch
tapeworm's Avatar
AC Delco shoes are usually very nice, as well as Raybestos (still American made I believe)
As for me, more cutting, grinding, welding; It never stops!
At least I have another ride for the summer
64 shortbox fleetside
replacing rusty junk with more junk, and one day to become a real truck again
tapeworm is offline
Old 01-11-2011, 05:28 AM   #2372
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Smacked my shin on the frame rails as I was walking through the dark shop to get to the fuse box.
I did start soaking the bed and cab bolts in JB Parts Blaster (similar to WD-40, but seems to work a little better). Next time I can get a spare set of hands to my shop I'm gonna try and get all those bolts out. Then all I need is an engine hoist and the cab and bed will be off.
fryer1979 is offline
Old 01-11-2011, 04:44 PM   #2373
kieth
kieth's Avatar
Installed:
front sway bar
fuel pump and return line
rear brake line
tv cable transmission
started trans cooler install
new thermostat
kieth is offline
Old 01-11-2011, 08:21 PM   #2374
janderson
took the steering wheel off to get to the turn signals, and took off the top of the heater box.
janderson is offline
Old 01-11-2011, 08:30 PM   #2375
JasonBird
'67 C-10 LWB Driver
JasonBird's Avatar
brushed some snow off of it and said i was sorry.....
'67 C-10 LWB - My Build Thread
'67 C-20 LWB - My Donor/ Parts truck - SOLD!
'92 GMC SAFARI VAN - My Parts Go Getter
'06 KIA SPORTAGE EX - My Commuter
"All of this crap better make a truck!" - my wife Sue.
Proud U.S.M.C. Dad!
JasonBird is offline
Closed Thread
