Old 01-09-2011, 05:29 PM   #1
Mattman2010
Mattman2010's Avatar
Dana 44 - Broken Spider Gear
I was starting to do a rebuild on my dana 44 front axle, and decided to pull the diff cover before i started to get to far into doing the rebuild. I found that the drivers side spider gear had teeth that where broken off, and several that where cracked.
How hard is it to replace spider gears? I know people say do not attempt to change gear ratios in a axle if it is your first time because it is a hard thing to do. So I am trying to figure out if I want to replace the spider gears, or just spend the money on a different dana 44.
Thanks, Matt
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 01-09-2011, 05:52 PM   #2
LONGHAIR
Re: Dana 44 - Broken Spider Gear
Changing spider gears is no big deal. The biggest thing to be concerned about is "where did the pieces go?" You have to be very meticulous about cleaning the housing out before you put this back together. The pieces can get up into the pinion area and through-out the bearings too. A lot of solvent and patience will be your friend here.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-10-2011, 04:59 AM   #3
K30_dump
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
K30_dump is offline   Reply With Quote
