Old 12-03-2010, 10:57 PM   #1
big10ratrod77
big10ratrod77's Avatar
duel exhaust on a 250?
hey guys i read somewhere that for like one or 2 years in the late 70s you could order a truck with a 250 stright six with duel exhaust... ive always wondered if it was the truth or not but i bought my 79 late this summer and it has factory split maniflolds , like it would have a duel exhaust set up and its got exhaust hangers on the drivers and passengers side. so i was just wondering if enyone could shed some light on this for me i think it would be neat if it was factory
thanks guys
Josh
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 12-04-2010, 11:51 AM   #2
geezer#99
geezer#99's Avatar
Re: duel exhaust on a 250?
You got a pic of your "factory" split manifold. I'm curious what it looks like!!!
geezer#99 is online now   Reply With Quote
Old 12-04-2010, 05:00 PM   #3
big10ratrod77
yea i do man
and it runs into a y pipe after that
Old 12-04-2010, 05:36 PM   #4
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I don't know about factory but any competent exhaust shop should be able to run you some "splits" seeing that you already have the correct manifold.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 12-04-2010, 05:37 PM   #5
geezer#99
geezer#99's Avatar
Any chance of a close up of the 2 flanges on the manifold.
Old 12-04-2010, 05:59 PM   #6
S10Fan
Old Heap Driver
That looks like an "Integrated Head" motor, the exhaust and intake manifold are cast as one piece with the head. I had one, ran duals with Thrush glasspaks, sounded like a Honda. LOL.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 12-04-2010, 06:29 PM   #7
big10ratrod77
i will when it stops snowing it has been some crazy weather today
yea i wanna run duel exhaust if i could find out if it was realy stock like that but i dont want it to sound "like a honda" idk what im gonna do about the exhaust realy yet wonder how it would sound with a high flow cat, with duel exhaust and no mufflers? or maby just flows?
Old 12-04-2010, 07:32 PM   #8
geezer#99
geezer#99's Avatar
I'm running Langdon's headers with 2 1/4 inch dual pipes and dynomax turbos on my 230.
Sounds like a small block at idle and while cruising.
Old 12-04-2010, 10:34 PM   #9
Keith Seymore
Keith Seymore's Avatar
Dual exhaust were not available from the factory (for the straight 6)
- BUT -
In 1980, the exhaust went down the left side.
In 1979, the exhaust went down the right side.
- SO -
On my 80 stepside, I just bought a '79 exhaust system and hung it on the right side (had to rework it a bit where it circles under the drive shaft), hooked it up to that dual outlet exhaust manifold and
VIOLA
true duals on a straight 6!
It had a very distinctive sound to it....
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 12-04-2010, 10:56 PM   #10
big_b
i once had a six in my '79 short box with dual 2" exhaust with 2 flowmasters. kind of a waiste considering it didnt really help out with performance being a stock 6 and all, it sounded cool though. people noticed the truck had duals and assumed it had a v8. it blew their minds when i popped the hood and people noticed it was a 6 cyl.
every 6 cylinder truck ive seen has that same manifold. its a 2 into 1 from the factory.
big_b is offline   Reply With Quote
Old 12-05-2010, 10:21 AM   #11
big10ratrod77
- BUT -
- SO -
On my 80 stepside, I just bought a '79 exhaust system and hung it on the right side (had to rework it a bit where it circles under the drive shaft, hooked it up to that dual outlet exhaust manifold and
VIOLA
K
thanks man i like what you did with your exhaust thats a good idea in gonna look into that monday do yall know of eny places that supply stock exhaust kits? so i could run a set up like this?
Old 01-10-2011, 03:21 AM   #12
custom63
custom63's Avatar
Big d.
How did the truck sound at idle with that setup? And when you got on the gas hard what did it sound like?
Tommy~
The difference between genius and stupidity is that genius has its limits
-- Albert Einstein
63 build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=317341
custom63 is offline   Reply With Quote
Old 01-10-2011, 07:04 AM   #13
D13
D13's Avatar
Integral head motors often came with dual outlet exhaust manifolds. Unfortunately there is no 'factory' dual exhaust system for standard heads. The down sides of the integrals outweigh the split exhaust.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 01-10-2011, 07:10 AM   #14
S10Fan
Old Heap Driver
Amen to that! One had been installed in mine at some point, the 454 looks way better and talk about "split manifolds"..........LOL
Prior to yanking out the 6 me and a friend bent up some dual pipes with glasspacks, we ran the pipes out the back. The truck sounded like a Honda, not good.
Bryan
