The One And Only !!!
Re: Anyone bought the LMC cargo lamp ?
If I had to guess (which I am) you drill a hole for that rubber plug to fit snugly then slide it in, Then install the screw threw the light base and into the threads in the rubber. As you snug the screw it swells the rubber for a tight weather proof seal, But don't over tighten it.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
| Bookmarks |
