Old 01-11-2011, 04:18 PM   #1
themb2g
Leaf Springs, front and rear
Hey all,
I am planning on re doing my suspension. I have a 72 Blazer and I think the front leaf springs are bad as they are fairly flat. They haven't hit the leaf spring blocks, which means they aren't completely spread out, but i wanted to see if someone could send me pictures of their front leaf springs on a 72 so that i can compare. A picture of some rear leaves wouldn't be bad for comparison either. Thanks all.
themb2g is offline   Reply With Quote
Old 01-11-2011, 04:25 PM   #2
Ridnhi
Ridnhi's Avatar
Re: Leaf Springs, front and rear
I have a 71 and 72 and both of them have flat front springs, I thought that something was wrong with the 71 when I bought it. But come to find out they were ok. I put a lift on the 71 but the 72 still has stock springs and they are flat.
1972 K5 Auto 4x4 factory air
2007 Silverado extended cab Z71
Ridnhi is offline   Reply With Quote
Old 01-11-2011, 05:27 PM   #3
cleszkie
cleszkie's Avatar
The stock front springs should have a slightly inverted arch to them. Upont compression, the rear shackles should rotate forward.
cleszkie is offline   Reply With Quote
Old 01-11-2011, 06:12 PM   #4
Ronnny
all through the years The front springs have had a flat or negative arch to them. That is normal
rd
Ronnny is offline   Reply With Quote
Old 01-11-2011, 11:21 PM   #5
themb2g
Thanks all.
