Closed Thread
Old 01-11-2011, 10:37 PM   #2376
cb1965
cb1965's Avatar
Re: What did you do to your truck today?
rebuilt a gmc grille. all new hardware, retaining rings, and headlights
cb1965 is offline
Old 01-12-2011, 12:12 AM   #2377
RioRancho62
Sunday: Pulled the crappy seat out that came with the truck. Removed the jerry-rigged speaker box out. Tried to mount the new seat to the stock brackets but needed some flat bar to make adapters so will git er dun next weekend. Found a 1/2" wrench, kitchen knife, 2005 high school football schdule, a pay stub and two packs of rolling papers under the seat.
RioRancho62 is offline
Old 01-12-2011, 12:24 AM   #2378
nachodog2
Hell yeah!!!
nachodog2's Avatar
finally brought mine home after having it sit at my brothers house. went needing some work came back in primer and a little lower.
Stock is good but custom is the sh*t!
nachodog2 is offline
Old 01-12-2011, 12:47 AM   #2379
sasquatch5308
sasquatch5308's Avatar
I put in the bench seat so I could sit in there and make "vroom vroom" noises... does that count? If not I worked on fabbing my motor mounts. Putting a 250 where the 235 used to be.
sasquatch5308 is offline
Old 01-12-2011, 02:07 AM   #2380
kalirodding
CLASSIX Truck Club
kalirodding's Avatar
Thats a pretty cool looking truck.
kalirodding is offline
Old 01-12-2011, 04:12 AM   #2381
tapeworm
fan of "Butters" Stotch
tapeworm's Avatar
Dig the supremes!
I had a set on a previous car, and sounds like I may have a deal worked out with the new owner to trade them back
64 shortbox fleetside
replacing rusty junk with more junk, and one day to become a real truck again
tapeworm is offline
Old 01-12-2011, 03:13 PM   #2382
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Pulled the engine back out!!!! as the builder used too long of a bolt on the balancer and it was not tight. Thus I have one huge POS... Starting over bought a 400 block and I get to reuse my heads intake and carb, headers, valve covers and oil pan. The rest is wiped out. Crank had .018 thrust, it took out the rods, pistons, Crank..well it had a craked key way so it was junk already. Block was not 30 over but 60 over.. He is out of biz and no one can find him..
GMR-PERFORMANCE is offline
Old 01-12-2011, 03:15 PM   #2383
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I have my truck off the road for a few weeks to get some stuff done.
The battery is being relocated under the bed on the passenger side. I got the box built for it last night and hope to install it tonight and wire it up.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline
Old 01-12-2011, 06:57 PM   #2384
gimmy 64
put in my new tilt column tommorow steering wheel and hook up electrical. the steering wheel is a red mettalic wheel from mooneyes
gimmy 64 is offline
Old 01-13-2011, 04:05 PM   #2385
kieth
kieth's Avatar
Pretty much finished the chasis, starting on the cab now, cleaning the bottom on the outside, will sandblast tomorrow, then will work on the floor on the inside, will repair rusted out places. POR-15 it then undercoat it next weekkkkk
http://kieth.smugmug.com/Trucks/66-G...55794128_yZNmN
kieth is offline
Old 01-13-2011, 09:15 PM   #2386
gimmy 64
here are pictures of new column and steering wheel
gimmy 64 is offline
Old 01-13-2011, 09:21 PM   #2387
nachodog2
Hell yeah!!!
nachodog2's Avatar
Thumbs up Re: What did you do to your truck today?
i like the it gimmy
Old 01-13-2011, 09:22 PM   #2388
kalirodding
CLASSIX Truck Club
Man that wheel looks good. Is that a Lokar shifter?
Old 01-14-2011, 11:07 AM   #2389
kieth
kieth's Avatar
Started working on the cab top and bottom of floor, rust is not too bad.......stuck the black bed wood in the bed just to see how it was going to look.....Kieth
http://kieth.smugmug.com/Trucks/66-G...56429338_SNvTB
kieth is offline
Old 01-14-2011, 12:59 PM   #2390
kieth
kieth's Avatar
took the heater core off and started to clean it out.......hmm do you think this is why the heater did not work ??
http://kieth.smugmug.com/Trucks/66-G...56508564_UKF6o
kieth is offline
Old 01-14-2011, 01:09 PM   #2391
protrash64
Resistance is Futile
protrash64's Avatar
.....looks like you cleaned your yard with it!!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline
Old 01-14-2011, 02:02 PM   #2392
Clyde65
Clyde65's Avatar
naaaahhhhh, looks clean to me!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline
Old 01-14-2011, 02:51 PM   #2393
gimmy 64
Lokar 23 inch shifter, mooneyes steering wheel
gimmy 64 is offline
Old 01-14-2011, 03:23 PM   #2394
CHUNK1962
Blew out the left front wheel cylinder and creeped it home with no brakes.
CHUNK1962 is offline
Old 01-14-2011, 04:33 PM   #2395
markeb01
Senior Enthusiast
markeb01's Avatar
Welcome to the forum. The good news being you made it home.
markeb01 is offline
Old 01-14-2011, 06:05 PM   #2396
lonestarluck
lonestarluck's Avatar
I bought my truck back from a friend today after trading it to him for a '72 Harley project about a year ago. It's in a million pieces but it's actually in better shape than when I traded it! haha
lonestarluck is offline
Old 01-14-2011, 08:53 PM   #2397
markeb01
Senior Enthusiast
markeb01's Avatar
Fabricated and installed brackets moving the fog lights 1 ¾” forward and down ½”. They had been mounted on top of the bumper, nearly in contact with the G & C grille letters. This blocked the view of the letters and made it difficult to clean the letters and the lamps. The new position also makes the lamps look more “important”. The brackets also permanently align the elevation, allowing deletion of the adjusting swivels. To properly align now all they need is left to right positioning. The best part was the project only cost $1.68 for some new nuts and bolts.
Here are a few before and after shots:
Before
After
Before
After
markeb01 is offline
Old 01-16-2011, 04:13 PM   #2398
jbgroby
jbgroby's Avatar
Just got back from the painter and he has the clear shot on the upper sections of the cab and dash. We're getting close boys!! The finish will be semi-gloss, the clear was still wet.
jbgroby is offline
Old 01-16-2011, 04:22 PM   #2399
markeb01
Senior Enthusiast
markeb01's Avatar
It looks beautiful in high gloss as well!
markeb01 is offline
Old 01-16-2011, 04:29 PM   #2400
TwoFiftyShifter
Bought a split bench seat off of craigslist. My bench is shot, needs new foam and a cover, which would cost more than the truck itself did, so I'm gonna use this one. Upholstery and foam are good it seems to be pretty comfy, almost as comfy as the the fact I got it for 20 bucks!
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline
Closed Thread
