Old 11-04-2005, 03:43 PM   #1
cypress TX 72
Saving one 72 at a time!!
cypress TX 72's Avatar
Wheel Bolt Patterns
Someone help,
I bought some meats with some old school aluminium mags, that came off a 72 Monte carlo, and I went to put them on one of my 72 cheyenne's --- but they don't fit ???????
I always thought that Chevy only had one 5 lug bolt pattern....
Can somebody clarify this for me.
TS
cypress TX 72 is offline   Reply With Quote
Old 11-04-2005, 03:46 PM   #2
68haywagon
I'm watching you!
Re: Wheel Bolt Patterns
They have atleast 2 that I know of- 5x4.5 and 5x5 I think are the numbers.
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 11-04-2005, 04:08 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
That is correct, 5 on 4 3/4 (car and S-10) and 5 on 5 (big car and trucks)
Old 11-04-2005, 11:06 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
In the same vein, Toyota has two 5-lug patterns....like the Celica and Camry use different spacing. Ford trucks, specifically the '83 models could have the passenger car spacing on an F-100, but not necessarily. I had an F-100 that had the regular 5 on 5.5 pattern that Ford has used for years.
Even though the later model GM full-size trucks use a 6-lug pattern, we can't just swap them onto our 70 and earlier trucks without some adaptation.
Ain't life fun?
Member Nr. 2770
Old 11-05-2005, 12:36 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Seems odd to me, because I would have sworn the Monte Carlo would have the big car/truck pattern....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-05-2005, 01:14 PM   #6
corn
Pretty sure the Impala & Caprice were the only "big" bolt pattern cars. Its crazy that there had to be so many different patterns. It sure would have been nice if the car companies just had a couple...
corn is offline   Reply With Quote
Old 11-05-2005, 01:33 PM   #7
raggedjim
raggedjim's Avatar
Here's a drawing that shows how to measure from lug to lug. I made a checker from a piece of wood and two short wooden dowels. If it drops in you know the wheel will fit.
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is offline   Reply With Quote
Old 11-05-2005, 01:45 PM   #8
Americanrider
The 5 on 5 "Big Bolt" patteren also was used on fleet cars such as Taxis, cop cars and anything that would see heavy duty. You can also find them on Caprice convertables. The disk brake rotors/hubs are interchangable with 5 lug 1/2 ton trucks too.
Americanrider is offline   Reply With Quote
Old 11-06-2005, 12:42 AM   #9
tiltbed69
yup All of GM`s fullsized cars used the 5" bolt pattern,caddy,buick,pontiac,ect also Ford,Linclon,and Mercury full sized BIG boats had the same 5" bolt pattern.intermediat GM`s are the only one`s that had a 4.75 bolt pattern ...Sid
tiltbed69 is offline   Reply With Quote
Old 11-06-2005, 01:37 AM   #10
Longhorn Man
Very true, and if you look for the cop cars, you may find an interesting rally wheel, they are normally black, but some paint and center caps/trim rings...and you have an interesting truck wheel.
Old 11-06-2005, 08:38 AM   #11
Tycoon4u
Tooloose
Tycoon4u's Avatar
Does this mean that rallys off a late model van will also fit or did they change after a certain year?
A legend in my own mind!!!
website: http://www.persmedequip.com/
'68 c10 (current project)
http://67-72chevytrucks.com/vboard/s...ht=cherry+bomb
'04 silverado (better halfs)
'07 wildcat 27rlwb(for sale) http://67-72chevytrucks.com/vboard/c...llinois&cat=17
Tycoon4u is offline   Reply With Quote
Old 11-06-2005, 09:19 AM   #12
Hart_Rod
Hart_Rod's Avatar
Truck/Van rallys have same bolt pattern.
Hart_Rod is offline   Reply With Quote
Old 11-06-2005, 12:39 PM   #13
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Van rallys are usually narrower. I run 8 inch truck rallys on the rear and 7 inch van rallys on the front. They look the same other than the inch difference in width.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-06-2005, 12:43 PM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
The round cooling holes like kinda neat. What width were they available in, 7" or 8" or both?
Articles-
"Refining Sierra"
Old 11-06-2005, 02:58 PM   #15
Longhorn Man
I was thinking they are 8 inch...but that pic looks more like a 7 incher.
Maybe it is both.
Old 11-06-2005, 09:07 PM   #16
Blue Beard
Blue Beard's Avatar
I got tired of trying to remember.....senior moment I guess....
Went to a local rod shop and bought a set of 4 plastic templates that will line up and show the sizes.
Cheap way, Les Schwab has a tire and wheel guide for free that lists most vehicles with diameters, offsets and alot of usefull info.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-11-2011, 11:26 PM   #17
Bryan S
Bryan S's Avatar
I'm looking at a set of custom wheels on a 2005 impalla, will this bolt pattern fit my 72 1/2 ton stock 5 lug truck?
Bryan S is offline   Reply With Quote
Old 01-11-2011, 11:47 PM   #18
Longhorn Man
wow... searched up a 6 year old post on your phone!
2005 Impalla would be front wheel drive so even if the bolt pattern is right (not likely) the back spacing/offset would be WAY off. You wouldn't be ablt to turn the front wheels all the way from lock to lock.
Old 01-12-2011, 12:27 AM   #19
Bryan S
Bryan S's Avatar
Thank you for the info.
Old 01-12-2011, 10:56 AM   #20
Shane
Shane's Avatar
for what it's worth, van rally wheels are 6 1/2" wide ... truck rally wheels came in 7" and 8" widths ...
Shane is offline   Reply With Quote
