Old 10-12-2009, 06:30 PM   #26
profe56
Re: Rear end conversion
Ok fire fighter> i saw the picture where you have all of the rear end interior parts unensembled and i understand you asembled in other rear end. Can i just change all those parts pinion etc in my c10 rear end instead of doing the conversion?
Probably my question is not clear , can i do anybody this question in spanish
profe56 is offline   Reply With Quote
Old 10-13-2009, 11:16 AM   #27
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
No, I just took the rear end apart to powdercoat it. After I coated it, I reassembled it back together, using new bearings.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 10-13-2009, 05:11 PM   #28
profe56
well: yesterday at the autoparts the clerk told me, why not just upgrade the ratio, thats why i´d like to know if can I just buy the necessary parts to do that, instead of change all the rearend but 73-87 parts could be installed in a
69 rearend
I´m adding a picture of actual rearend it has, I understand that should be better open the rearend to see what exactly is. also I was thinking of I could keep 6 lugs and original
Old 10-15-2009, 05:11 PM   #29
dragitvinn
Ok so im really confused.. The whole rear is over to the drivers side two inchs more than the pass. side .. But the where the drive shaft conncts its it is not dead center of the axle.Its over one inch to the pass side.. Is it suppose to be centered or what? The rear in my 1969 chevy C20 came out of a 1994 chevy tahoe 2500.. someone help me...
1972 Chevy suburban sale
dragitvinn is offline   Reply With Quote
Old 10-15-2009, 05:40 PM   #30
chevy_mike
Never Ending Projects
chevy_mike's Avatar
69 rearend
It's not just a simple swapping parts over, anyone can do that. It is the fact that the gears have to be setup with the correct backlash, preload, shims and pattern. If you don't the gears will not last very long and they will make a very bad howling noise as they destruct themselves.
You can have the ratio changed in your current rear end but I would HIGHLY suggest you take it to a pro to have done. I can HIGHLY recommend Mark at Pro Gear in Kearny Mesa. The only shop I have work on diffs for me.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-13-2011, 03:42 AM   #31
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Again,
thanks everyone for your contributions, and especially the pics.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
