Re: Which freakin steering box do I need? 1981 short wide 2 wheel drive!
I assume you've already eliminated slop from worn joints, etc.? It's pretty rare that a steering box actually craps out or wears to the point of being a problem. They can be rebuilt, too.
Building Dreams out of Dimes!
Yeah I replaced the idler arm as well. Tightened and regreased everything. I just want to go ahead and replace everything I can, within reason, before I put in my engine.
I mainly just want to improve my steering and handling all around. I figured replacing the steering box might help with the slop in the steering wheel. If I'm wrong or somone has a better idea please let me know. Thanks! Also will this steering box work? |
#3 | |
The One And Only !!!
See the nyloc nut on the top cover in the pic you posted, With the engine off loosen this nut and turn the screw in the center inward 1/8 turn at a time until the slop is gone (turn screw check slop/turn screw check slop). Then start the engine (when you get one in) (DO NOT HAVE YOUR HANDS ON THE WHEEL) and re-check for slop, You can adjust too tight and the wheel WILL spin on start up and break fingers/thumbs. If your box isn't leaking I wouldn't replace if adjusting solves the play issue. If you want to replace it anyway CALL Summit tech support and tell them what you want, They have good tech support and will be able to hook you up..... ![]()
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
