Old 01-13-2011, 08:08 PM   #6
ironroad9c1
Master Hater
Re: Pegged heat gauge - faulty gauge or thermostat?
DO NOT remove the thermostat completely, the water will not stay in the radiator long enough to cool off Just buy a new 195 t stat and be done, Also side up under the front of the engine and see if the water pump is seeping out of the weep hole. could be dripping on the belts while it sits and Antifreeze and belts don't mix.
1997 C1500 ECSB 4.3/NV3500 8.5 3.42
"This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors
ironroad9c1 is offline   Reply With Quote
