Old 01-13-2011, 11:10 PM   #1
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Which freakin steering box do I need? 1981 short wide 2 wheel drive!
Originally Posted by Hazieview View Post
I figured replacing the steering box might help with the slop in the steering wheel. If I'm wrong or somone has a better idea please let me know. Thanks!
See the nyloc nut on the top cover in the pic you posted, With the engine off loosen this nut and turn the screw in the center inward 1/8 turn at a time until the slop is gone (turn screw check slop/turn screw check slop). Then start the engine (when you get one in) (DO NOT HAVE YOUR HANDS ON THE WHEEL) and re-check for slop, You can adjust too tight and the wheel WILL spin on start up and break fingers/thumbs. If your box isn't leaking I wouldn't replace if adjusting solves the play issue.
If you want to replace it anyway CALL Summit tech support and tell them what you want, They have good tech support and will be able to hook you up.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
