Old 01-15-2011, 08:28 PM   #1
Kmart2352
Kmart2352's Avatar
355 True Duals
I just got a 355 put in my truck and I am looking to put true dual 3 inch mufflers and i just want to see what people have the best sound with, with duals?
87 2wd GMC Sierra Classic.
86 4wd GMC Sierra Classic.
95 2wd GMC Sierra.
96 2wd Chevrolet S-10.
Kmart2352 is offline   Reply With Quote
Old 01-15-2011, 08:46 PM   #2
codydubb
codydubb's Avatar
Re: 355 True Duals
Flowmaster all the way.
1985 Chevy C10
350 .60 over iron eagle h-beam rods, sealed power high comp pistons, forged crank, vortec heads, edelbrock performer rpm vortec intake, roller rockers, .488 .510 cam 750 Demon Double Pumper, Longtube headers, Dual Flowmaster exhaust,Dual electric fans, Proform electric water pump. TCI 3500 Stall Converter th350 trans B&M shift kit 10 bolt 3.73 Detroit Locker
codydubb is offline   Reply With Quote
Old 01-15-2011, 08:46 PM   #3
thesickc10
Re: 355 True Duals
i also have a 355 i run dual 2.5 exhaust though hedman headers and flowmasters super 40's. truck sounds like a beast
1985 c10 355 th350 (working on 4 speed conversion to super t10)
1979 camaro 358 super t10
2003 f250 superchip slp exhaust
thesickc10 is offline   Reply With Quote
Old 01-15-2011, 08:48 PM   #4
codydubb
codydubb's Avatar
Re: 355 True Duals
Mine is a 360 2 1/2" with super 40s sounds amazing. Why are you going 3 inch?
1985 Chevy C10
Old 01-15-2011, 08:58 PM   #5
Kmart2352
Kmart2352's Avatar
Re: 355 True Duals
the headers are 3 inch and i would like to keep it 3 inch all the way out
95 2wd GMC Sierra.
Old 01-15-2011, 09:06 PM   #6
bbbc10
Diggin The SquareLife
Re: 355 True Duals
3" flowmasters wth 40 series!!!!!!!!!!!!!!!!!!!! thats what i have on my truck an i also have a 355....it sounds sick!!!
bbbc10 is offline   Reply With Quote
Old 01-15-2011, 09:23 PM   #7
Kmart2352
Kmart2352's Avatar
Re: 355 True Duals
I am also going to put the pipes out in front of the wheels but at a different angle. Is the sound a very low tone or is it different than that?
95 2wd GMC Sierra.
Old 01-15-2011, 09:40 PM   #8
chevyC-ten
chevyC-ten's Avatar
Re: 355 True Duals
3 inch super 44's sound pretty mean
chevyC-ten is offline   Reply With Quote
Old 01-15-2011, 09:42 PM   #9
mooseknuckles
mooseknuckles's Avatar
Re: 355 True Duals
what are true duals?
mooseknuckles is offline   Reply With Quote
Old 01-15-2011, 11:44 PM   #10
bbbc10
Re: 355 True Duals
its not that much of a low tone i say....u can feel my truck runing at my neighbors house...an when i get on my truck you can hear it from a pretty good damn distance....
Old 01-16-2011, 12:19 AM   #11
Pop's C-10
Pop's C-10's Avatar
Re: 355 True Duals
1 pipe/muffler per side from header/manifold all tha way back & out to tha tailpipe
Pop's C-10 is offline   Reply With Quote
Old 01-16-2011, 01:10 AM   #12
bitchin85
bitchin85's Avatar
Re: 355 True Duals
i have a 355 with a mild cam. long tube headers, 2.5 inch duals into super 44s turned down before the axle. sounds awesome
it had cherry bombs, sounded like poop
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 01-16-2011, 02:17 AM   #13
pig rig
pig rig's Avatar
Re: 355 True Duals
running 3" pipe for a small block your going to loose a lot of bottom end power and at speed it will sound like its about to come apart
Im running 3" all the way out to be hind the wheels on my crew cab with a big block and hooker aero chamber mufflers. on the freeway people look back to see whats comming up beside them its LOUD
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 01-16-2011, 02:20 AM   #14
bigblock73
yeller
bigblock73's Avatar
Re: 355 True Duals
I agree, 3" is waay too much pipe for your average small block.
bigblock73 is offline   Reply With Quote
Old 01-16-2011, 02:25 AM   #15
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Re: 355 True Duals
I'm running 2" true duals from the factory manifolds all the way back without cats and with some Flowmaster knockoffs (figured they would be temporary but I like them) and then down to 1.5 inch chrome tips in the back (for that old school look) it sounds really nice, not to loud but you can hear it from a ways away but doesn't drone in the cab.....hopefully will sound better when I install some new headers..
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 01-16-2011, 02:50 AM   #16
bbbc10
Re: 355 True Duals
well i dnt have ur average sb...its built for spray an it has no back pressure.....it really dnt sound like it gona come apart when i get on it....
Old 01-16-2011, 11:42 AM   #17
maynardtruckin
maynardtruckin's Avatar
Re: 355 True Duals
bigger pipe deeper sound
Chris
67 c10 swb build in progress
70 c10 lwb driver pending parts for drastic overhaul
70 c20 lwb parts truck for above mentioned drastic overhaul
71 k20 lwb building for off road use and towing
maynardtruckin is offline   Reply With Quote
Old 01-16-2011, 11:59 AM   #18
Kmart2352
Kmart2352's Avatar
Re: 355 True Duals
The motor that I bought is ment for little back pressure and is ment to ment open.
95 2wd GMC Sierra.
Old 01-16-2011, 12:03 PM   #19
maynardtruckin
Re: 355 True Duals
with the right muffler and a few bends in the pipe back pressure is not a problem. look at copper head 3" pipe all the way back.
Chris
Old 01-16-2011, 12:06 PM   #20
russgt
russgt's Avatar
Re: 355 True Duals
Copperhead had a 572, 3 inch pipes on a 350 will actually cost you some torque
70 stepside
76 blazer
86 Sierra Classic
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 01-16-2011, 12:14 PM   #21
mod58
Re: 355 True Duals
Running 355 with 2.5 and spintech Sportsman F Series,wakes up the neighbor's!!!!!!!!!!!!!!!!!!!!!!
mod58 is offline   Reply With Quote
Old 01-16-2011, 12:19 PM   #22
maynardtruckin
Re: 355 True Duals
I didnt notice any loss personaly on my dyno runs.
Chris
Old 01-16-2011, 12:26 PM   #23
maynardtruckin
Re: 355 True Duals
loud pipes save lives.
Chris
Old 01-17-2011, 08:02 PM   #24
Kmart2352
Kmart2352's Avatar
Re: 355 True Duals
They sure do
95 2wd GMC Sierra.
Old 01-17-2011, 08:04 PM   #25
Kmart2352
Kmart2352's Avatar
Re: 355 True Duals
How do you think corsa would sound true duals?
95 2wd GMC Sierra.
