Old 01-09-2011, 05:09 PM   #1
Andice
Andice's Avatar
'64 GMC Steering Wheel Diagram?
When I pulled the steering wheel off last weekend a small, split, cylindrical bushing feel out of the back of the wheel as I was about to lay the wheel down on the truck seat. Does this bushing go inside the opening on the back side of the wheel? Or do I slip it down on the column shaft? It seems like it may come into contact with the horn contact ring and possibly distort the ring and/or the upper column bushing as I torque down the wheel upon re-install. One end of this bushing is tapered. Taper up or taper down when re-installed? I'll go out and take an image or two of this bushing. An original assembly diagram would be appreciated. Thanks in advance.
Andice is offline   Reply With Quote
Old 01-09-2011, 06:46 PM   #2
Andice
Andice's Avatar
Re: '64 GMC Steering Wheel Diagram?
Here is an image of the bushing. Notice the tapered end.
Old 01-09-2011, 06:46 PM   #3
Clyde65
Clyde65's Avatar
I believe that is the turn signal canceling cam.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-09-2011, 06:57 PM   #4
Andice
Andice's Avatar
Methinks the canceling cam is black plastic and still screwed to the back of the wheel. This piece is thin metal.
Old 01-16-2011, 12:19 PM   #5
Andice
Andice's Avatar
at
