Old 01-15-2011, 06:34 PM   #1
TugOwar
Dual wheels on a dana60?
I thought of running duel wheels on my 68 GMC 2500. It has a dana60 (8-lug) rearend. Can this be done? what, if anything must be modified? longer wheel studs perhaps? Any help appreciated.
TugOwar is offline   Reply With Quote
Old 01-15-2011, 06:53 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Duel wheels on a dana60?
Do you want a wide set up like the pickups, where you need fenders, or do you want a cab and chassis style, where the added tire is more inbound and the outer is only moved out a little bit?
Old 01-15-2011, 07:12 PM   #3
TugOwar
Thanks for the reply LHM,
The latter I suspect. I don't want to change the factory fleetside bed or add anything (like mudflaps) if I don't have to. I do have leaf springs if that makes a difference. Also, are all 8-lug wheels the same bolt pattern regardless of make?
Old 01-15-2011, 10:43 PM   #4
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
8 lugs are the same for all GM, IH, Dodge, and Pre 97 Ford (8x6.5). 97 and Later Ford are slightly different (8x170mm).
What can get you in trouble is the centerbore of the wheels. I have a set that won't fit my 68 K20 because my D60 rear's drive flanges are too big.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 01-15-2011, 10:48 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I did it and had to press longer studs into the hubs and run a 3/4 inch spacer between the inner wheel and brake drum.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-16-2011, 09:34 PM   #6
TugOwar
Was there a follow up to this question sir? Seems like you needed my answer to your question before you could answer my question? Or am I totally fusterclucked in my thinking here.
