Old 03-21-2010, 12:16 PM   #51
jason65
Registerd User
jason65's Avatar
Re: project lownslw64
Fantastic.
jason65 is offline   Reply With Quote
Old 03-21-2010, 01:20 PM   #52
4dranch
Shloooooong bed member #2
4dranch's Avatar
very slick, nice work
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 03-22-2010, 05:23 PM   #53
64shortc10
64shortc10's Avatar
Lookin good lownslw64! Where did you end up getting the high hump trans cover? And how far are you from Faifeild, Ca.? I might have to come check this thing out some time!
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 03-22-2010, 05:43 PM   #54
Bazooka
Keepin it old school
Bazooka's Avatar
Is that Griffen Radiator made for our trucks? or is it a universal fit? Looks freakin sweet
Bazooka is offline   Reply With Quote
Old 03-22-2010, 11:42 PM   #55
lownslw64
lownslw64's Avatar
Tony from Norcal
thanks, I bought the high hump from a board member lil red 66. I bought that and my radiator mounts from him. He is very knowledgable and has alot of parts. I live in brentwood, nor cal. I am about a hour from fairfield south east. off of hwy 4. pm me if you want to come and check it out.
1963 Chevy suburban, ls1/4l60e, 3 rows, barn doors
2007 chevy 2500 hd 4x4 duramax
lownslw64 is offline   Reply With Quote
Old 03-22-2010, 11:55 PM   #56
lownslw64
lownslw64's Avatar
yes, the radiator is made for our trucks. It is a 4 core alum radiator with dual elec fans, transcooler and mine I set up for my ls1 ( both inlet and outlet are on the pass. side). If your truck did not come with a 4 core rad. you will need the upper and lower bracket from a stock 4 core truck and they will fit the radiator. The part # for mine is 6-563ar-jax so if you want to look at it on there website and you can fine tune it more for your application (motor,transcooler) thanks for the complements.
Old 04-11-2010, 12:15 PM   #57
lownslw64
lownslw64's Avatar
well I bought a couple of parts and i thought i would share. first is a art big red 3/8'' manifold valves and second is the ride pro e3 electronic management system for my air ride. The bonus of this kit for me was I don't have to run all of the air line and wiring into my cab. It all goes to an ecu in the frame and a small multi-conductor cabe is routed into the cab to the controller that tells me everything i need to know.
Old 04-11-2010, 11:20 PM   #58
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
looks like a good set up you got there. only good things about he ridetech stuff.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 04-12-2010, 04:19 PM   #59
Dinos63
chevy only
Dinos63's Avatar
Duuude nice work very cool!!
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 04-23-2010, 01:31 AM   #60
lownslw64
lownslw64's Avatar
I've been off this week so i have been able to work on my truck a little more than usual. so I figure I would try to eliminate some loose ends. I got the brake lines in the rear up to the front x-member complete. not sure how i'm going to run the fronts yet. made a bracket off of the trailing for my e- brake cable. installed my air tank, manifold valve and started on plumbing in the 1/2tubing for the air ride.
Old 04-23-2010, 02:23 PM   #61
c10Mang
c10Mang's Avatar
Looks good!! Can't wait to see this thing rolling.
c10Mang is offline   Reply With Quote
Old 08-30-2010, 07:38 PM   #62
64shortc10
64shortc10's Avatar
Any updates?
Tony from Norcal
Old 08-31-2010, 12:02 AM   #63
lownslw64
lownslw64's Avatar
no updates really. bent a couple air lines, thats about it. been busy with the family and life..... hope to get back on it soon.
Old 01-09-2011, 01:41 AM   #64
lownslw64
lownslw64's Avatar
i've been able to work on my truck a little bit lately. I mounted my water seperator, finish bending and install all of the air lines to all four corners. i will hopefully soon get my fuel system taken care of and get started on cab repairs.
Old 01-09-2011, 01:54 AM   #65
PBFAB.COM
PBFAB.COM's Avatar
That plumbing is artwork!
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-09-2011, 02:27 AM   #66
Captainfab
60-66 Nut
I agree! Looks great.
Old 01-09-2011, 03:04 AM   #67
SCOTI
SCOTI's Avatar
Wow! That's freakin' nice.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-09-2011, 11:59 AM   #68
Dinos63
chevy only
Dinos63's Avatar
lot a work looks killer!!
Old 01-09-2011, 12:43 PM   #69
lownslw64
lownslw64's Avatar
thanks everybody, been wanting to do this to one of my truck for a long time so it is nice to finally acomplish it.
porterbuilt: i am getting ready to have a driveline built. i have a dropmember with a ls1/4l60e tranny with 4 degrees on it and the stock 12 bolt trailing arm setup. what is the best way to figure out my 2 piece driveline needed. including angles . thanks
Old 01-09-2011, 09:43 PM   #70
lownslw64
lownslw64's Avatar
picked up a o1 camaro ls1 fuel tank today to use the fuel pump assembly in my fuel cell. I will have to modify my fuel cell for this to work. It would be awesome if i could use that whole tank and everything but it is to wide.
Old 01-14-2011, 02:24 AM   #71
lownslw64
lownslw64's Avatar
i unbolted my fuel cell tonight to figure out how i am going to mount my fuel pump into it and figured while i was back there i would mount my 67-72 fleet rear bumper.
Old 01-14-2011, 10:48 AM   #72
daverod
SSN 706
daverod's Avatar
Love the air lines. Looks way clean. You make it look to easy.
daverod is offline   Reply With Quote
Old 01-16-2011, 11:31 PM   #73
c10Mang
c10Mang's Avatar
those lines are awesome!!
Old 01-17-2011, 01:56 AM   #74
65Pickup
65Pickup's Avatar
I know you've heard it a few times, but nice plumbing job!!! Couple questions though, could you show us the tool you used to fab such a large tube and are those all flared fittings, compression? Thanks in advance, this is a great post.
65Pickup is offline   Reply With Quote
Old 01-17-2011, 12:44 PM   #75
lownslw64
lownslw64's Avatar
thank you for all the compliments
65 pickup: the tool i use to bend the tubing is a ridgid tubing bender for s.s. tubing. I used 1/2 s.s. x 036 (thickness)tubing for my lines. I used parker cpi s.s. single ferrull compression fittings for everything. I dont know max pressure rating but they are mainly used in process and instrumentation applications. the first pic is the bender and i put a piece of tubing in it to give you the idea and the second is the fitting i use opened up so you can see all the pieces.
