Old 01-17-2011, 10:17 PM   #1
72MARIO
72MARIO's Avatar
How much wight can it Tow ?
Just wondering how much weight my 68 Suburban should be able to pull with out over working it. It has a 327 T400 and 3:73. Looking at pulling a 4000lb camping trailer.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-17-2011, 10:21 PM   #2
Re: How much wight can it Tow ?
C10 or C20?
If it is a lot, I'd recommend air bag helpers since you are very low already, towing wise.
Old 01-17-2011, 10:34 PM   #3
72MARIO
72MARIO's Avatar
Sorry it`s a C10 I am going to put 2600 bags in the back in place of the stock coils.
2005 TAHOE DD
Old 01-17-2011, 10:49 PM   #4
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I'm not sure what the limit is, but I think you could pull 4000 lbs just fine. Just make sure your cooling system is in good shape (clean coolant, right antifreeze mix, shroud in place, good fan clutch, 3 row or bigger radiator that's not plugged up, good thermostat, no leaks, etc.) and if you don't have a separate tranny cooler you might consider adding one. Also make sure your tranny filter and fluid and diff fluid are in good shape. Then enjoy the ride!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 01-18-2011, 12:22 AM   #5
into69z
"brand new second-hand"
into69z's Avatar
consider a load leveling hitch to help spread the weight evenly to the front and rear axles...........
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
