Old 01-17-2011, 03:52 PM   #176
kart34
Re: Extreme Powder Coating '65 C-10 Shop Truck
Steel for boxing frame was .109 thick.
kart34 is offline   Reply With Quote
Old 01-17-2011, 11:56 PM   #177
kart34
Question Re: Extreme Powder Coating '65 C-10 Shop Truck
Hey guys I need some help. We are ready to start rebuilding the stock 65 12 bolt open rear end. Were do I purchase 5x5 axles / brake drums / seals /etc?
Old 01-18-2011, 12:09 AM   #178
Captainfab
60-66 Nut
The axles can be found at Summit Racing as well as some of the differential specialty guys like Randy's Ring and Pinion. I believe CPP and ECE have the axles also. Any of the other parts such as bearings, seals, shoes and related hardware can be sources from your local auto parts supplier. If I may make a suggestion.....I would upgrade to the wider shoes as found on the '76(?) and newer C10 12 bolts. You will have to change the backing plate and of course the drums, shoes and internal hardware. If you need to replace the original parts anyway, may as well upgrade while you're at it.
Old 01-18-2011, 12:12 AM   #179
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
http://www.speedwaymotors.com/1963-7...Kit,46254.html
Trying to remember who I bought the last set from...but I found this link?
wutnxt is offline   Reply With Quote
Old 01-18-2011, 08:43 AM   #180
lucifer
lucifer's Avatar
Cool Re: Extreme Powder Coating '65 C-10 Shop Truck
Moser has agreat deal on axles. They can also make em whatever length or bolt pattern. Great guys to deal with.
I ordered a pair of customs axles and three days later they arrived.
Luc
65 burb On the road Mar 26th Finally
lucifer is offline   Reply With Quote
Old 01-18-2011, 09:43 AM   #181
Dirty Doug
Dirty Doug's Avatar
Greg I can get strange axles for the same money as moser . Custom built to your specs. Just another option for you. I also have a deal to buy Moser if you want them .
Dirty Doug is offline   Reply With Quote
Old 01-18-2011, 02:48 PM   #182
kart34
Speedway Motors axle kits are on backorder ( 2 weeks) We need this ride rollin for Winterfest car show by Feb.10 . I really do not need custom built axles just a good oem set.
Old 01-18-2011, 02:50 PM   #183
lucifer
lucifer's Avatar
Moser has them in stock ...same day shipping
Luc
Old 01-18-2011, 03:41 PM   #184
SCOTI
SCOTI's Avatar
Luc
I hope they've improved the fit of these. I purchased a set back in 2000 to use on my 68. The splines would not engage the spider gears. I tried filing them down slightly after discussion w/them w/no success. I ended up shipping the axles back to them w/one of my originals (so they could see the splines weren't messed up). I also taped (yes, slid on & taped in place) one of my spider gears so they could see what I was encountering.
I got the axles back a week or so later..... w/no spider gear. According to them, I didn't send a spider gear (remember, it was taped in place). So, approx 3wks after the original receipt of their axles, I had some that fit better, but now I had to source another spider gear since I had one missing.
I procured another spider gear only to still have issues getting the axles fully seated enough to install the c-clips. It seems the bearing races aren't machined in the exact correct area or the axle lengths are incorrect as there is wear on the differential pin that keeps the axles seated.
This was on a factory 6-lug, 1968 12-bolt housing. Like I said, hopefully things are better.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 01-18-2011, 03:52 PM   #185
Scottshotrods
Moser does have them in stock and we have been useing them for the last 6 yrs have had no problems at all.They will stand behind there products 100%.If we can help you out let us know
Justin
Scottshotrods is offline   Reply With Quote
Old 01-18-2011, 04:56 PM   #186
kart34
Talking Re: Extreme Powder Coating '65 C-10 Shop Truck
Almost there with all the custom fabrication by Wally's Speed Shop a division of Extreme Powder Coating
Old 01-18-2011, 05:04 PM   #187
kart34
***SNEAK PEAK*** This is our idea for floor pan - going big and exposing the PorterBuilt C-Notch!!!!
Old 01-18-2011, 09:38 PM   #188
Alvin
Never Done?
Alvin's Avatar
Allllright - we will admit that we are using some FORD parts on this 'lil Chevy pick-up truck...grrrr...
You're looking at a 1965 Mustang fuel tank AND (the best buy ever) 2010 Mustang Shelby GT 500 take off mufflers. EBAY score - $20.00 a pop!
I just came across the mufflers on ebay myself earlier today. Certainly a great deal. What are your thoughts (since you've seen them in person)? If I got them I would probably need to modify the inlet pipe, in your opinion is that do-able?
Thanks!
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 01-18-2011, 09:54 PM   #189
kart34
Alvin, The inlet could be cut off with no problem and re-fabbed with a straight inlet. Very well built muffler.
Hey I really dig your truck .....and may buy a tire and wheel combo like your using also for my truck .
Old 01-18-2011, 10:31 PM   #190
Alvin
Never Done?
Alvin's Avatar
Thanks man! I think I'll pick up a pair of the mufflers.
I am really happy with the look of the wheels... wish they offered a different width for the back, but it still works.
This truck you're building is pretty epic! I'm loving all the detail work going into it, keep it up!
Old 01-19-2011, 12:00 AM   #191
kart34
Wink Re: Extreme Powder Coating '65 C-10 Shop Truck
Thanks, We built a 67 Buick Wagon a few years ago with 145 powdercoated parts on it. It was a huge success for my job shop. The car was featured in Hot Rod and Car Craft magazine and has received several Good-Guys awards. SOOO we needed a new project !!!
Stay Tuned !!!!!!
Old 01-19-2011, 05:15 PM   #192
kart34
Rims came in from Delmo today and finishing up welds on bed mounts.
Old 01-19-2011, 06:10 PM   #193
kvn1011
Kvn1011
kvn1011's Avatar
Jesse is rockin on that bed!! looking good!!
kvn1011 is offline   Reply With Quote
Old 01-20-2011, 12:08 AM   #194
Mad Rods
Chevy Only Tx
Mad Rods's Avatar
Coming along great kart.....man y'all work fast!!!
Chevy Only Tx.........
Mad Rods is offline   Reply With Quote
Old 01-20-2011, 12:11 AM   #195
67chevy1series
67chevy1series's Avatar
are those were the hub cap screws in those holes on the rim how ezactly does that work
67chevy1series is offline   Reply With Quote
Old 01-20-2011, 08:12 AM   #196
kart34
67 chevy, There are 5 clips that bolt on.
Old 01-20-2011, 08:37 AM   #197
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Wow... you guys are not holding back on this; nice work!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-20-2011, 05:34 PM   #198
kart34
Been working hard today on getting the front end put together. Front fenders and grill surround.
Old 01-20-2011, 05:37 PM   #199
72BlckButy
Tot Roddin'
72BlckButy's Avatar
What's up with the repop fenders? Were the originals to rough?
-Nate
Old 01-20-2011, 05:46 PM   #200
kart34
Got it all fitted and bolted on the frame. Hopefully this thing is ready to roll soon. Then we'll be powdercoating all the parts we possibly can!
'65, c-10, carter hickman designs, extreme powder coating
