Old 01-17-2011, 11:17 AM   #201
67C10BUB
67C10BUB's Avatar
Re: '67 5.3L Build Thread
Originally Posted by awhite4557 View Post
What radiator hoses did you use? I have a 71 chev C-10 and am installing a 2001 5.3 out of a GMC Suburban and the GMC Suburban hoses are too small for the 71 Radiator fittings?
I used the factory 5.3 hoses. They will slide on with a little silicone spray. I know they are a little small, but they seem fine once attached. You will have to trim the lower one down so it doesn't kink.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 01-17-2011, 07:33 PM   #202
awhite4557
awhite4557's Avatar
I'll give it a try, just wanted to make sure before I forced anything. Thanks.
1950 Chevy 3100 Ramp Bed 1-ton
http://67-72chevytrucks.com/vboard/s...d.php?t=749386
1965 Chevy Step Side
1971 Chevy Short Wide Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=277191
1971 Chevy C-30 1-ton
1971 Chevy Chevelle
1972 Chevrolet C-30 1 ton
2005 Dodge Ram 2500 5.9 Cummins
2017 Fleetwood Pace Arrow 35M motorhome 350 Cummins
2020 Jeep Wrangler Unlimited Rubicon
awhite4557 is offline   Reply With Quote
Old 01-18-2011, 12:29 AM   #203
1sik7t2
dave
1sik7t2's Avatar
thats what i did, but mounted the cooler to my core support between it and the grille, with higher pressure lines, not sure how high, with barbed ends...THEY told me it would work
Originally Posted by rob32472 View Post
Just a suggestion but why not just install a cooler on the frame rail close to the trans? It would be about the same money and look sweet!
check out my build "DIRTY BURB"
1sik7t2 is offline   Reply With Quote
Old 01-18-2011, 01:17 AM   #204
mcbassin
Still Learning
mcbassin's Avatar
Originally Posted by 67C10BUB View Post
I used the ECE ls motor install kit. I also used their trans x-member and everything bolted in perfectly. I highly suggest it.
Thanks, I am going to try to make some adapter plates and use the 73 up motor mounts like you used.
Old 01-20-2011, 12:43 AM   #205
awhite4557
awhite4557's Avatar
Thanks for the help, I sprayed silicone on the hoses and fittings and the hoses slid right on.
1971 Chevy Chevelle
Old 01-20-2011, 06:27 AM   #206
67C10BUB
67C10BUB's Avatar
No problem. Glad I could help.
67 5.3L Build
Old 01-20-2011, 06:54 AM   #207
67C10BUB
67C10BUB's Avatar
Got the new master cylinder/booster installed this weekend and put in all new brake lines. The front is the 6770FLK brake line kit from CPP. I spoke with Mario at CPP at he helped me out tremendously. He is a really great guy who is building a truck himself, so he knows how difficult things can be. If anyone else is planning on doing the same as me (Grand Slam kit and 6770FLK brake line kit) make sure to ask for 1/4" brake hoses with your grand slam. You can also see the CPP steering shaft kit. It upgrades to a universal joint at the top, a new rag joint, and a slip joint on the shaft. It is very easy to install since you just cut the stainless shaft in the middle to size and slip it in.
67 5.3L Build
Old 01-20-2011, 06:57 AM   #208
67C10BUB
67C10BUB's Avatar
I also got a new track bar from CPP and had my drive shaft shortened and balance at Inland Empire Driveline. They also put new U-joints at both ends and put in a 27 spline slip yoke to mate up to the 4L60E. I am lucky that they are so close to me (right down the street).
67 5.3L Build
Old 01-20-2011, 07:02 AM   #209
67C10BUB
67C10BUB's Avatar
I sent my ECM back to John at Speartech and had him remove the DOD/AFM function that was giving me problems (as some may have noticed on my other thread). The motor now runs 100X better and is super smooth. All codes are gone except for a bank 1 and 2 lean code. I was wondering if someone might know if this is because my crankcase ventilation tube is on the filter side of the MAF rather than the manifold side. Does it matter?
67 5.3L Build
Old 01-20-2011, 12:52 PM   #210
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I wouldn't set it up like that. Seems like you'll be getting the MAF dirty much faster pulling engine vacuum/oil residue.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-20-2011, 03:41 PM   #211
67C10BUB
67C10BUB's Avatar
Very good point. I think I will relocate it no matter what.
67 5.3L Build
Old 01-20-2011, 03:58 PM   #212
c10seconds
c10seconds's Avatar
Looks awesome!
c10seconds is offline   Reply With Quote
Old 01-20-2011, 09:51 PM   #213
68GMCCustom
if you've never cleaned the throttle body (and behind the throttle plate) on one of these LSx motors after 15k-25k miles or so.... you'll find lots of black soot all over the back. There's no fuel or coolant....and not supposed to be anything but air in one of these intakes? Surprise! Its pulling oil residue from the pcv (and who knows where else).
Kurt -
Old 01-21-2011, 06:41 AM   #214
67C10BUB
67C10BUB's Avatar
Good info, thanks. Any idea what might be causing my lean codes? I am thinking about getting a steam iron and see if I can see anywhere that the intake might be leaking.
67 5.3L Build
Old 01-21-2011, 04:09 PM   #215
68GMCCustom
well I'd have to guess......but if your getting the code on both banks, then (unless you have 2 bad 02 sensors) the only way for it to run lean on both sides is the injectors aren't doing what they should be (and are being commanded to do by the PCM to do) doing....or....you have a intake leak?
Kurt -
Old 01-21-2011, 05:38 PM   #216
67C10BUB
67C10BUB's Avatar
The O2 sensors are new and the injectors were just professionally cleaned/balanced. I must have an intake leak I think. It just seems hard to find.
67 5.3L Build
Old 01-21-2011, 06:37 PM   #217
68GMCCustom
If the intake is like mine was it has a plastic gasket frame with a rubber sort of o-ring style gasket around each port. Possible one of o-rings got pinched?
Kurt -
Old 01-21-2011, 09:54 PM   #218
67C10BUB
67C10BUB's Avatar
I believe it is the same, but I have never had it off. It went out of the wrecked truck and into my truck. I didn't take it apart at all, so I have no clue what's going on in there. I may take it to a professional and have them troubleshoot it.
67 5.3L Build
Old 01-24-2011, 02:50 PM   #219
67C10BUB
67C10BUB's Avatar
Here is how I modified my intake. I cut out about 4" of the long tube and swapped it with the MAF.
67 5.3L Build
Old 01-24-2011, 02:53 PM   #220
67C10BUB
67C10BUB's Avatar
I also got the bed back on this weekend and drove the truck under its own power. It was very exciting, but I have a few brake line leaks I have to take care of. I haven't figured out what I want to do for the wood in the bed yet, so I left it empty for now. Looks kinda' cool for now.
67 5.3L Build
Old 01-24-2011, 10:45 PM   #221
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
Congrats on the test ride, truck looks great, almost a shame to put a wood bed in and cover that nice work up, but I'm sure the wood you install will look just as good as the rest of the truck.
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 01-24-2011, 10:56 PM   #222
68GMCCustom
what are your plans for the fuel inlet on your tank? I have the same one and am trying to decide to put a door in the wood that opens up to the filler below.....or cut the top off my tanks filler...and put a marine setup in with a flush cap in the bedwood and a short rubber hose to connect to the tank neck.
Kurt -
Old 01-25-2011, 12:44 AM   #223
67chevy1series
67chevy1series's Avatar
its nice and lite did yu fry the tires a little ,does it have the power you were exspecting
67chevy1series is offline   Reply With Quote
Old 01-25-2011, 06:33 AM   #224
67C10BUB
67C10BUB's Avatar
I am just going to put the billet door in the wood. It looks like it should work out fairly well and I can get the billet door at Auto Zone for $50 and it is keyed.
67 5.3L Build
Old 01-25-2011, 06:35 AM   #225
67C10BUB
67C10BUB's Avatar
No, I didn't get to test the power yet. I wanted to get the brake line leak fixed before I got crazy with it. Plus, it is pretty loud with the open headers, so I may wait for exhaust to do the real test drive.
67 5.3L Build
