01-12-2011, 08:14 AM | #1 |
C10 Club Tennessee
How low in the rear for suburbans?
Didn't know if it was like a truck or not because of the weight.
Thinking about springs but fighting off the urge to go bags. I don't want to cut into the floor. I will run a 3rd row seat. Thought about running bags with schrader valves, but that can be a pain. Posted via Mobile Device
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
01-12-2011, 08:55 AM | #2 |
67-72 parts collector,…
Re: How low in the rear for suburbans?
I had a 69 'burb years ago with 6" rear drop springs, and no c-notch.
(4/6 total drop) I think you will want a c-notch on anything more than a 5" drop. (I used truck springs) I'm not sure if anyone make a 'burb specific spring.
01-12-2011, 06:16 PM | #3 |
its all about the +6 inches
i have 4 inch coils, dropped more like 6 to 7 inches (truck coils) and the axle would slam into the frame if I nailed the throttle from a standstill, let alone ANY kind of road irregularity. I installed helper bags inside the coils and keep it at a 5 to 6 inch drop with no problems
01-12-2011, 06:52 PM | #4 |
C10 Club Tennessee
See that's what makes me want to bag the rear. Andy, did you c-notch it? I've lowered tons of these trucks just not sure what the difference is when it comes to the burbs.
01-12-2011, 07:37 PM | #5 |
I put RE7 bags in the rear with a single schrader. My burb is a 3/4, the ride was great, many compliiments on the handling for bag rear/coil front suspension. I rode with 31" tall tires with the body 1/2" above. I could have rode with the body lower but I put a 14 bolt FF corporate rear in. not as much space. I mounted a compressor in the back so that I didn't have to pay (even air cost $ now!) when I needed to add. plus, met/helped many with flat/low tires. If I was to give any advice, go with the bags on the rear, you fill your Burb with 6 people average weight of 175 lbs. 1050 ibs. plus gear. it's nice to have options.
I do plan on bags on the front with full controls, Burb is in the body shop, hopefully everything done by May. Al.
1972 GMC Sierra 1972 GMC Super Custom Suburban |
01-12-2011, 11:27 PM | #6 |
I have 3" CPP coils it's more like a 6" drop. I am going to bag the back without a notch. Just run shrader valves for now. The CPP or ECE super track bar kit. SCOTI's shock relocate mod. Thinking of the RE7 bags. I am not going to notch yet because it would just turn into a step notch.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
01-13-2011, 12:48 AM | #7 |
BlahBlahBlah
If you go with lowering coils make sure you get the burb lowering coils. They are much more stout than the truck coils. Ive posted pictures of truck and burb lowering coils side by side here before, unfortunately I dont have them on this computer.
… … … … … … … … ... … … … … … … … … … … … Last edited by CG; 01-13-2011 at 12:48 AM. |
01-13-2011, 02:11 PM | #8 |
I think that i read on GMC pauls site that they carry/have made Suburban specific drop springs?? might wanna check that out for sure tho?
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
01-13-2011, 02:54 PM | #9 |
C10 Club Tennessee
This sounds like bags might be the way to go. Just don't want to cut into the floor.
01-14-2011, 11:36 PM | #10 |
born to lose
this is good info to know. I almost bought drop springs for a truck to put on my burb glad i didn't.
_____________________ '67 Chevy Belair Wagon 283 Powerglide '68 Chevy II Nova 2 door 350 TH400 Sold!! '71 Chevy C20 350 TH350 '71 Chevy C10 Burb 350 TH350 stolen totalled gone.... Burb Build http://67-72chevytrucks.com/vboard/s...d.php?t=475155 Nova Build http://67-72chevytrucks.com/vboard/s...d.php?t=498979 Wagon Build http://67-72chevytrucks.com/vboard/s...d.php?t=543052 Not giving a truck. |
01-15-2011, 02:00 PM | #11 | |
Any ideas? Shawn Posted via Mobile Device
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
01-15-2011, 08:10 PM | #12 |
sorry, just now reading this form... i hace no installed a notch.
My recomendation if the funds are there is to just go with bags. otherwise, spend the extra for burb coils. even with the helper bags, the ride is too mushy for me as it sits. |
01-17-2011, 03:31 PM | #13 |
jorgensensc - Shawn, I installed plates on the top and bottom, and used Firestone 2500 bags. I haven't tried them yet as the Burb is in the shop getting body and paint. I'm not sure what bag psi I will be using. I'm hoping for 80 to 100 lbs. If I don't reach that pressure I will cut the plate and install a cup on the bottom. I completly removed the bump stop and bracket. I will be installing a custom bump and steering stop........eventually. I will post a pic when I'm back on my other computer.
01-18-2011, 03:16 PM | #14 |
You can go with a bolt in CPP c-notch and you will not have to cut the floor. Check out my Burb build thread....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 01-18-2011 at 03:24 PM. |
01-18-2011, 03:24 PM | #15 | |
On a side note, after looking at it your right I will need to trim the steering and bump stop bracket. That's no biggie. I am just not wanting to have to shell out money for drop spindles too. Shawn Posted via Mobile Device
01-18-2011, 08:14 PM | #16 |
here's a pic shawn, I'm not liking the angle of the bags. Not sure if the angle is okay?
Al.
01-18-2011, 09:11 PM | #17 |
Thanks for the picture! I hate to ask, but can you measure fromthe top plate to the bottom plate that hold the bag? Between those two places on my a-arms with load (big block, body, etc) there is roughly 5".
Thanks! Shawn Posted via Mobile Device
01-18-2011, 11:17 PM | #18 |
if you go to brotherstrucks.com you can get everything to do a 4"/6" spring drop front and rear for either the burb or truck about $1000 includes a bolt in notch drop spindles panhard bar front and rear swaybars shocks and springs and I think it comes with new control arms but not sure all you need to add is the time to install I am saving to get this kit for my burb but I will weld the notch on instead of bolting it on
they say you can go as low a a 5" drop in the rear without notching the frame
a wise man once said "There are only two real rules to life... 1 - Don't sweat the small stuff 2 - Everything is small stuff Last edited by 71gmcburb; 01-18-2011 at 11:22 PM. |
