Steel crank 327??
Looking at 68 LWB GMC tomorrow, wants me to make an offer.
AC cab 327 Tires are rotted off, hasn't been ran i a few years His uncle bought it new... says the rust is not bubbled up and only the rockers are in really bad condition in his add. I haven't asked any questions yet, figure I will wait til I see it in person. He thinks that the 327 with a steel crank is rare. I don't know anything about this. Is there something I don't know? I am so anxious to have one of these trucks I am afraid that I am going to over pay. I am thinking of offering $500 and going from there. ![]() ![]() |
Re: Steel crank 327??
I wouldn't say the crank is real rare. I guess it's a fairly rare 327 crank. '68 was the last 327 truck motor and they were large journal (like 350s) with steel crank. I have one from a '68 Chevy truck. I assume this one will be the same casting. I don't recall the numbers but I ran mine down and its the same block as the '68 Camaro SS350 (350hp) and '68 Z/28. In my mind they are very desirable engines. They were rated @250hp.
#3 | |
like specialk already stated, there are large journals, and small journals. as far as i see it, all the small jornals are is a PITA to find another crank for. believe me, i have one sitting outside in a crate.
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains ![]() Quote:
![]() want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there |
Fabricate till you "puke"
An LJ 327 crank is pretty rare in a 2wd pickup....I have heard of guys pulling them from a 4wd, or BIG truck, but they were most common in muscle cars from the era. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
![]() Join Date: May 2007
All small journal 327 cranks were steel. A large journal steel 327 crank is pretty hard to find. I parted a 68 1/2 ton once upon a time, and it was a steel crank. You won't know if it's steel untill you pull the pan.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
steel as opposed to what ?wood? I asked that question long ago to someone looking for a crank . Well I thoght it was funny . Sorry . Jim
500 looks about right. The grill looks like it is in good condition and it is probalby worth about 1/2 that.
I just rebuilt my 327 and it was a large journal 69 out of a camaro. Good luck.
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake 1968 C10 flatbed 307 w/ 4 spd manual (dads old ride) 1936 1/2 tn pickup, 400sb 350 turbo (partially restored) 1949 1/2 tn, needs complete restore (future project) 1969 Chevy impala 4 dr no post (wifes future car) 2010 GMC Serria 4x4 crew, leveling kit |
#8 | |
fat old dude
![]() Join Date: Feb 2010
hmm i scrapped the 327 off a 64 impala ss 2 weeks ago
1972 c-10 shortbed 350/400 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157 1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216 Accepting part donations |
What?
If you have a good eye and a flash light, and you can get under the engine and trans. Sometimes you can look up at where the crank meets the fly wheel, and if you see a wide cast ridge it's a steel crank. If it is a narrow cast ridge it is a cast iron crank.
Steel cranks, and 4 bolt main blocks are of no concern if you are just building a truck motor or even a hot little street thumper IMO.
Chris 1968 K20 Suburban 1972 K10 LWB PU Last edited by vectorit; 01-19-2011 at 01:10 AM. |
Junior Member
![]() Join Date: Mar 2007
Just a little related hijack. Are 283 cranks small journal?
frontstreetcycle on Instagram |
Yes....
The first small blocks were small journal and smaller displacement(265,283,327). GM bumped the displacement up and went to a larger journal from that day on. All 305,307,350,400s,and the last 327s are large journal. I know in trucks the change occurred in '68 and,as far as I've seen,all these last 327/first large journals were steel cranks.
They say "steel" crank for forged steel which is stronger than the more common cast steel. I always said "forged crank",but the majority won out and I say steel now.
Thanks for the input, was supposed to call for directions today to meet him there at 10am, no answer though...
