Old 01-18-2011, 12:44 AM   #1
Puglia10
Angry pics of stock control arms/front suspension please 73-87
Hey guys, mind posting up some pictures of your control arms for square bodies? My bushings arent going in and I want to make sure I have everything right. I dont see what could be wrong...by themselves, on a frame, together or apart, any pics will help...thanks!
1979 c30 3+3 dually
1946 GMC
Puglia10 is offline   Reply With Quote
Old 01-18-2011, 12:49 AM   #2
54Caddy
GM Addicted
54Caddy's Avatar
Re: pics of stock control arms/front suspension please 73-87
Might want to look in my build thread in my signature some pictures may help you out
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 01-19-2011, 12:35 AM   #3
fishingjred73
fishingjred73's Avatar
I just took mine off today I'll post you some pics up tomorrow.
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 01-19-2011, 01:02 AM   #4
Puglia10
awesome thanks! anything will help
1979 c30 3+3 dually
1946 GMC
Old 01-19-2011, 07:42 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-19-2011, 09:40 AM   #6
Puglia10
awesome! thats what i wasnt sure of, it seemed like the shafts were too long cause those bushings dont sit flush on the outside, it looked weird. But yours are the same way so i guess thats right? how do you know how far to go, do they have to be exactly even?
1979 c30 3+3 dually
1946 GMC
Old 01-19-2011, 12:17 PM   #7
fishingjred73
I see TX beat me but since I took em I'll post em anyway.
James
Member of
Old 01-19-2011, 12:54 PM   #8
Tx Firefighter
The bushings have a raised step around them. You press them in until the step is against the control arm.
Old 01-19-2011, 02:18 PM   #9
fishingjred73
How do you get the old one's out?
James
Member of
Old 01-19-2011, 05:21 PM   #10
fishingjred73
Finally got the uppers out, now trying to get the lowers out.
James
Member of
Old 01-19-2011, 05:23 PM   #11
Puglia10
thanks everyone. to get them out we used a big press and an air chisel, and a torch on one that wouldnt move....it was a huuuge PITA
1979 c30 3+3 dually
1946 GMC
Old 01-19-2011, 06:20 PM   #12
Tx Firefighter
I remove the nuts and washers then set the bushings on fire with a torch. I throw them on the pavement in front of the shop and let them burn until they're done. Then, with the rubber absent, it's an easy matter to fold the outer sleeves inward and push them out with an air hammer.
Old 01-20-2011, 02:20 PM   #13
Puglia10
Okay, the new ones are pressed in!...... but the bump stop area is still crushed. Is that all necessary? The slit for the bump stop on the left, then the right side has a hole drilled (whats that for?) and then the piece sticking out from that, is that the steering stop? Has anyone else had crushed ones, what are my options? It seems impossible to recreate that perfectly as I dont have measurements from a good one or anything. Thanks
1979 c30 3+3 dually
1946 GMC
Old 01-20-2011, 02:22 PM   #14
Puglia10
pics for reference what im talking about, sorry...
1979 c30 3+3 dually
1946 GMC
Old 01-20-2011, 10:41 PM   #15
peglegs
peglegs's Avatar
TexFirefighter ty for posting the tip on removing the bushings your method worked out perfect and if you dont mind me adding that any residual rubber doesnt harded when cooling & spreads like the plauge, lol, burn it all!
1990 chevy 4x4 with a 1940 IHC body
peglegs is offline   Reply With Quote
Old 01-20-2011, 11:05 PM   #16
N2TRUX
Happy to be here
N2TRUX's Avatar
Okay, the new ones are pressed in!...... but the bump stop area is still crushed. Is that all necessary?...
I prefer to run bump stops but thats just me. I hate it when a suspension system bottoms out and there are no stops to absorb the impact.
If it were me I would torch that off and grind it smooth. Then you can add an aftermarket stop or build one to the height that you need. Here's what we did on my 77.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-21-2011, 02:13 AM   #17
Puglia10
Thanks n2trux, that looks good. Do you have any more pictures? And how would you know how tall and wide to make it? And what about the steering stop part? Not needed?
1979 c30 3+3 dually
1946 GMC
