Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > Review Board > Product Reviews
Old 01-21-2011, 12:24 PM   #9
GMCPaul
Re: GMC paul door seals are great!
Originally Posted by bigsnookmaster View Post
I have Precision seals on my truck, and my doors are a bit hard to close. If I were to swap out to these, do you think it will make a difference in the closing pressure? Thanks
If you have Precision glue on door seals and are having difficulty closing the doors I'd suspect that either the ends are butted tight causing the air to be trapped in the seal making door closure hard, or the doors need adjusting at either the hinges or door striker. The doors should close virtually if not exactly the same useing either our Glue on version by Precision or the push on version.
Paul @ GMCPauls
GMCPaul is offline   Reply With Quote
