Old 01-18-2011, 01:08 PM   #1
Mikedub82
Mikedub82's Avatar
Z'd frame?
Should i run into serious mods with 2.5 or 3inch z. I've heard that 4 inch creates many problems. Trying to lay out with 2.5 drop spindles bags and z'd frame. Will I have to cut trans/ driveshaft tunnel for any amount of Z I do?
Get Low
Mikedub82 is offline   Reply With Quote
Old 01-18-2011, 11:23 PM   #2
Brad2thabone
Brad2thabone's Avatar
Re: Z'd frame?
Search, search, search, man. Don't go anything past 3" you'll be in a lot of trouble then. Im not sure on the trans tunnel, maybe have to run a high hump trans pan from a 4x4?
Brad2thabone is offline   Reply With Quote
Old 01-19-2011, 10:42 AM   #3
DHPmike
DHPmike's Avatar
Re: Z'd frame?
3" is the way to go or a dropped crossmember.
DHPmike is offline   Reply With Quote
Old 01-19-2011, 08:54 PM   #4
rotgg
Re: Z'd frame?
by lay out what do you mean do you mean frame, pinch weld, or rocker
rotgg is offline   Reply With Quote
Old 01-19-2011, 11:37 PM   #5
DHPmike
DHPmike's Avatar
Re: Z'd frame?
you can lay the frame or pinch with a 3" Z. If you want to lay the pinchweld you will need to cut off about an inch and a half off the bottom of the frame right under the cab about where your feet are.
Old 01-19-2011, 11:39 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Z'd frame?
It would help if you told us what year truck, and SWB or LWB.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-20-2011, 10:03 AM   #7
Mikedub82
Mikedub82's Avatar
Re: Z'd frame?
1966 swb stepside. I would like to lay rockers.
Get Low
Old 01-20-2011, 10:36 AM   #8
scotts62
One day...
scotts62's Avatar
Re: Z'd frame?
Mine with a 2.5 Z made in the new frame, illl look for a better pic..
Could have went lower but i left room for oops's and i didnt grind the truck to a nub before i got stopped.
Scott
93 crew cab build
Project 62
Old 01-20-2011, 11:10 AM   #9
Mikedub82
Mikedub82's Avatar
Re: Z'd frame?
I guess a better question would be, If the frame is on the ground, how low is the body?
Get Low
Old 01-20-2011, 07:59 PM   #10
dv8customs
dv8customs's Avatar
Re: Z'd frame?
A straight edge and a tape measure will tell you that
dv8customs is offline   Reply With Quote
Old 01-20-2011, 08:06 PM   #11
jbjburbs
jbjburbs's Avatar
Re: Z'd frame?
time is money...i'd invest in drop member and let the cnc machine do the measuring...
John J
Bodied 1994 Suburban on custom frame -
http://67-72chevytrucks.com/vboard/s...d.php?t=672297
Dad's 1948 Suburban -
http://67-72chevytrucks.com/vboard/s...d.php?t=563150
Bagged 1995 Suburban - SOLD
Bodied 1995 Tahoe -SOLD
jbjburbs is offline   Reply With Quote
Old 01-20-2011, 08:46 PM   #12
kev2809
low n' slo
kev2809's Avatar
Re: Z'd frame?
if you have the coin a drop member would be the better option.
but if not (like most of us), there is nothing wrong with a z if you do it right. 3" should lay the frame with your setup. just dont do like the guy that had a 6" z..lol
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 01-20-2011, 11:08 PM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Z'd frame?
Originally Posted by kev2809 View Post
..... there is nothing wrong with a z if you do it right.....l
That is correct, "If you do it right". Most I have seen are not done right.
Articles-
"Refining Sierra"
Old 01-21-2011, 08:35 AM   #14
DHPmike
DHPmike's Avatar
Re: Z'd frame?
3" Z and 1.5" off the bottom of the frame, the curved part under the cab and it will lay pinch weld. Thats pretty simple..
Old 01-21-2011, 02:58 PM   #15
Mikedub82
Mikedub82's Avatar
Re: Z'd frame?
I am going to stick with the 3in Z, and drop spindles and see how low that is before I start cutting any more frame away. Thanks for all the info from everyone.
Get Low
