Old 06-30-2003, 09:47 AM   #1
BigRed
Starting Problems :(
I drove my truck several times this weekend and had no problems. I came back from a buddy's house yesterday, showered and cleaned up, then got back into the truck to go somewhere. Wouldn't start. It would cranka and crank, but not turn over. I could smell gas eventually so it probably got a little flooded.
So, I called the wife to pick me up and let it sit for several hours. Came back home and it started fine.
So, I let it run for while and then shut it down.
I went out this morning to go to work and the same problem again. Wouldn't turn over. I know it wasn't flooded when I first tried to start it but it eventually did when I was trying to get it going.
Another weird thing about it is that if I try and crank it and it doesn't go, I don't turn the key off. When I do that and try and start it again, sometimes the starter will just spin. And sometimes the starter keeps spinning even after I turn the key back. However, if I try and start it and then turn the key all the way back to Off and back to start, it doesn't do that???? Weird stuff.
My questions are:
1. What should I look at first with the problems with turning over? What should I check?
2. Do you think that maybe the ignition switch is bad and that is what is causing the starter to keep spinning even after I bring the key back to off? If not, what could it be.
I'll have a little time to work on it this evening, so any suggestions would be nice.
Thanks!
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 06-30-2003, 10:29 AM   #2
BigRed
One other question. If the ignition switch is bad, could that cause the coil to not get power?
Scott Shelbourne
Old 06-30-2003, 11:48 AM   #3
PHOENIX
are you getting spark?
when you say the starter is spinning do you mean its spinning freely as if its not engauging with the flexplate/flywheel?
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 06-30-2003, 11:50 AM   #4
BigRed
I haven't had time to look at it yet. I was getting spark (obviously) the one time yesterday when it started. That's one thing to check. Thanks
Scott Shelbourne
Old 06-30-2003, 11:56 AM   #5
PHOENIX
Well you may have something wrong and spark comes and goes as it pleases.
If it is cranking and not starting I would check the spark everytime it doesnt start.
Do you have power going to the distr.?
Are you saying when you try to start it and it fails to start you turn the key off and the starter still spins?
Old 06-30-2003, 12:06 PM   #6
BigRed
Not sure if I'm getting power to the dist yet. I won't be able to look at it until tonight. I'm actually weighing more towards the ignition switch now. I think I'm randomly getting power to the coil.
Yep, the starter still spins even when I back off of the key. It stops when I get it back the off position and wiggle it a little.
Scott Shelbourne
Old 06-30-2003, 10:28 PM   #7
tazman
could poss be the switch--something else you might check is the coil itself--sometime the coil starts breaking down on it way to a final shut down
tazman member of Mojave Street Rods
tazman is offline   Reply With Quote
