Old 01-22-2011, 08:22 PM   #1
Project77
Blinker issues(electrical)
okay today i just went out to check everything on my truck and when i went to check the blinkers they wouldnt work properly the lights would light up inside and outside but wouldnt actually blink(blink... blink... blink) anyways this is its first time doing that how do i fix it could it be a fuse issue or...
Project77 is offline   Reply With Quote
Old 01-22-2011, 08:25 PM   #2
customizer76
Re: Blinker issues(electrical)
Head to your local parts store and get you a heavy duty flasher and your problems should be over.
customizer76 is offline   Reply With Quote
Old 01-22-2011, 09:22 PM   #3
one low c10
I have the opposite problem mine work intermittently on off on off on off haha just goofing......X2 on the flasher
one low c10 is offline   Reply With Quote
Old 01-23-2011, 01:01 AM   #4
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
You should have two flashers, one for the emergency blinkers and one for the directional signal blinkers. At least, I have two in my '78. The flasher on the fuse panel is for the emergency blinkers. The directional flasher is mounted under the dashboard, to the left of the steering column.
78 Big10 454 is offline   Reply With Quote
