Old 06-30-2010, 11:02 AM   #26
383tbi
Re: R134 condensor
Originally Posted by 87chevy.com View Post
i have the stock condensor and evap in the truck. orielly orfice tube and accumulator, stock 5.3 compressor and after i put the fan shroud on the truck the vent temps are at 50* after 5 mintues of driiving. charged the system to 1.85ish lbs and the pressures were at 28-35low and 200-220 on the high. good enough in my book. I had it at 1.75lbs but the compressor would cycle at idle.. added the extra .1 and it doesnt cycle as much and the high side pressures only went up like 5psi..
clint
I imagen you are running elec fans correct.
383tbi is offline   Reply With Quote
Old 06-30-2010, 11:18 AM   #27
383tbi
Re: R134 condensor
The later style compressor that originaly designed for r-134 is probably making the difference.I wouldn t mind those temps either.
Old 07-19-2010, 03:13 PM   #28
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Re: R134 condensor
i got told that this will lower the temp of the system but not the vent temps for those wondering, because of how large and efficient the truck style condenser already it. My area gets to around 95 with a heat index of 110ish, maybe in the hotter regoins it may be better.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 07-19-2010, 03:54 PM   #29
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: R134 condensor
I have been holding off on replacing my new OE-style 85 condenser with this style. I wanted to see how well the OE condenser performed in the hot, hot weather with the 5.3's compressor. In the few 100° plus days we've had in the last 2 weeks, it will still freeze me out! I think if you already have everything apart while you are doing a swap, this would be a good choice. But don't discount the OE condenser, it will still make icicles.
** EDIT - I just checked the part number of the one I bought, Visteon P/N 2083 from O'Riley. In the specs it says "Utilize popular parallel flow and 6 mm designs. " So I guess that explains why it works so good! Sounds like the same one, or very similar.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-19-2010, 07:27 PM   #30
CaliDude76
All About the BOWTIE
CaliDude76's Avatar
Re: R134 condensor
I pretty much have stock everything.... except 134a refrigerant.. here in Cali it's been 100+.. and pushing close to 50* vent temps on these days...stop and go traffic.. 60(+-) cooler days, lower temps... Im impressed for a 26 yr old A/C system
CaliDude76
"... Being "SQUARE".. is where it's at...."
Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..."
Be exceedingly blessed today, my friends!...
CaliDude76 is offline   Reply With Quote
Old 01-23-2011, 11:09 AM   #31
JMac11
JMac11's Avatar
Re: R134 condensor
Any word on on the condenser upgrade results??
JMac11 is offline   Reply With Quote
