Old 01-23-2011, 03:44 PM   #1
coggonobrien
Window regulator, restore or replace?
Windows don't roll up/down worth a crap on my blazer. Should I buy new regulators or restore the old? if the answer is restore what's the steps? sandablast/bush/paint/etc?????
Thanks,
David
coggonobrien is offline   Reply With Quote
Old 01-23-2011, 04:23 PM   #2
kcsa75
kcsa75's Avatar
Re: Window regulator, restore or replace?
Thanks,
David
Before you do anything else, I'd spray some lithium grease on the moving parts and a little silicone in the channels. You may be surprised what a difference it makes.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 01-23-2011, 04:44 PM   #3
cdowns
cdowns's Avatar
i'd actually spray the heck out of them with wd40 first to clean out any petrifried crap then once clean and working well i'd spray them with the lithium grease to lubricate for a prolonged lifespan
Old 01-23-2011, 04:53 PM   #4
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Cleaning & lubricating is fine, but if the small plastic wheels which roll up and down the channels are worn...and lets face it after forty odd years of use!!!
I replaced mine.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 01-23-2011, 04:59 PM   #5
Duncan and son
Thanks,
David
Neither... if cleaning etc does not work I would contact a member like Randy "teeitup" , Dennis "sharpie" or someone that has nice original.
Hope that helps Paul
You can shear a sheep every year, but you can only skin it once
The person dealing with facts is never at the mercy of the person dealing with theory
1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn
1975 Silverado 454 Crew cab camper special dually
Duncan and son is offline   Reply With Quote
Old 01-23-2011, 05:04 PM   #6
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Heard 'new' regulators are crap and break, I think sinister had this problem?
John
1999 Toyota Tacoma 4x4
Old 01-23-2011, 05:05 PM   #7
coggonobrien
10-4 thanks guys, gotta love this place!
Old 01-23-2011, 05:34 PM   #8
sameyrasmea72
sameyrasmea72's Avatar
I would check the weather stripping that goes down the door frame and down through the long brace in the door. They tend to break up and keep the window from sliding like it should. Also the long vertical weather stripping on the vent window. The fuzzy stuff comes off and blocks the glass from working good. Most of the regulators I have seen work fine if you clean/grease them AND CLEAN OUT THE TWO GROOVES that the glass slides in.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 01-23-2011, 05:39 PM   #9
eightbanger
454 MAKES IT ROAR
Finding a set of original regulators that have not been rolled up and down much in their life would be rare as rocking horse s**t, when I took mine out to clean and lube I discovered that one of the plastic wheels on the PS had seized at some point in the past and worn itself flat on one side with continued use, the drivers side which sees the most use had all the wheels worn smaller with rolling up and down rusty channels which made them prone to fall out of those same channels. My replacements have been in and trouble free for nearly 3 yrs now, I'd say these parts are only as strong as the little plastic wheels on the ends of the regulator arms.
Nigel.
No more pain.
Old 01-23-2011, 06:35 PM   #10
redmonster
redmonster's Avatar
ive had my new window regulators in for about a year now and have had no problems with them. they're great
WITNESS
Dont be like me be better than me
redmonster is offline   Reply With Quote
Old 01-23-2011, 07:02 PM   #11
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I've been using the same repop window regulator for about 10 years.I do keep it and the tracks lubed but don't really see any reason to complain about the repop.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-23-2011, 07:09 PM   #12
Sinister
Between Trucks...
Sinister's Avatar
Yeah, I'm searching for a solution before it gets too warm here. Repop from Classic Parts died after a couple of years. PanelDeland do you remember where you got yours?
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 01-23-2011, 07:40 PM   #13
pat 70/71
pat 70/71's Avatar
I agree! first clean the regulator & lube it up. On some I've had the crank was striped out but, most will respond with a good cleaning/ lubrication/test. I have in the past bought the repop regulators I find the stock ones to work smoother& better! best of luck to you. cheers, Pat
pat 70/71 is offline   Reply With Quote
