Old 01-23-2011, 11:26 PM   #1
72gmcshorty
72gmcshorty's Avatar
Anyone bolt in notch?
Has anyone done a bolt in c-notch on a 72 2wd blazer? If so, which brand did you use? any issues with the rear frame horns?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 01-24-2011, 11:14 AM   #2
SOON2BLAZE
SOON2BLAZE's Avatar
Re: Anyone bolt in notch?
Never done it, but I believe any of the 67-72 truck bolt in ones would work.
SOON2BLAZE is offline   Reply With Quote
Old 01-24-2011, 01:58 PM   #3
YBNORML
YBNORML's Avatar
I used the cpp version. It bolted in with no issues.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 01-24-2011, 02:12 PM   #4
OG2wdblaze
OG2wdblaze's Avatar
considering the same thing...would love to see pics of total drop with bolt in and installation pics if possible.
OG2wdblaze is offline   Reply With Quote
Old 01-24-2011, 04:03 PM   #5
tubbedII
needs more $$$
tubbedII's Avatar
I mine a few weeks ago, nothing too bad except for stubborn rivets. I used CPP's, and as long as you have a true 2wd frame with coils, it should bolt in like any other truck. I liked CPP's since it' referenced off exisiting holes to make the cuts easier to determine where they should be.
I didn't take any pics of it, but I used this link from Rokcrln as a guide: http://67-72chevytrucks.com/vboard/s...d.php?t=195566
OG2wdblaze: I had a 4/6 drop on mine without a notch and I only bottomed out a few times. The pic is with 22's and about a 31" tire. I'm still in the middle of bagging it, and with a 2" block, bags and c-notch, the rear tucks tires with no air.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 01-24-2011, 08:34 PM   #6
SeventyOne
This is coming from a 4x4 guy - that is one nice looking Blazer
SeventyOne is offline   Reply With Quote
Old 01-25-2011, 03:41 AM   #7
OG2wdblaze
OG2wdblaze's Avatar
wow, I need to do some more research...Im not sure that is much lower than what Im sitting at now. Thoughts?
Old 01-25-2011, 04:35 AM   #8
tubbedII
needs more $$$
tubbedII's Avatar
Thanks!
I think you're at about stock height. My avatar is the sake 4/6 drop, but with shorter tires. The 22's raised it up some.
1970 2wd Blazer
