There should be a wire( usually lt green) that comes from the A/C control in the cab, to the pressure switch on the accumulator. The other side of the pressure switch(usually dk green) goes to one terminal of the compressor clutch. The other side of the compressor plug is ground.
In other words the switch is in series with the compressor clutch coil. HTH.
69GMC-C soon to be K20, 73 Chevy K20, 79 Chevy K20 , 85 Chevy K10, 86 S10 4x4 with a Small Block, and a 2002 Silverado |
| Bookmarks |
