I've got a question on a 72 chev truck. PLEASE HELP
I am trying to hook up a toggle switch to start my truck. But i want it so you have to have the key in the igniton and in the start position, then hit the toggle to have the truck start. Anyone have any answers I would appreciate it thanks.
BlahBlahBlah
Re: I've got a question on a 72 chev truck. PLEASE HELP
Ill PM a mod to move this to the appropriate spot so you get the answer you need =)
I did the same mod to a 79 chevy van I used to own,(key was so worn it wouldn't work anymore) it uses the same key switch as our trucks. take off the connector on the back of the key switch, it tells you what wire does what, one will be labled start , cut that wire and install your momentary on toggle between the ignition wire and start wire and you will be able to do a remote start in it and still use the orig key to power everything it is low amp so you won't need a big toggle
a wise man once said "There are only two real rules to life... 1 - Don't sweat the small stuff 2 - Everything is small stuff |
If I understand you want to have the key switch in the START position and have to use the momentary switch at the same time to start it? Just splice the start wire on the back of the key switch to run through the momentary switch. That way the momentary switch wouldnt get power until the key switch is turned to start.
Name: Les ---------------------- Couple 80s Couple 70s One 68
#5 | |
![]() Join Date: Feb 2001
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
| Bookmarks |
| Tags |
| 1972, 355, chevy c-10 |
