Old 01-25-2011, 04:12 AM   #6
mongoose
mongoose's Avatar
Re: trying to convert 4x4 blazer to 2wd
Originally Posted by bluex View Post
http://67-72chevytrucks.com/vboard/s...d.php?t=377142
Here is another one. I posted pictures of a '90 jimmy that has been converted in that thread. That truck is not mine......
The plan on mine is to remove the front spring hangers, rad support (I'm swapping to a '76 front clip as well so they have to move anyway) engine mounts and crossmember and install the 2wd crossmember and rad support mounts. Everything else will stay, you will have to swap to a 2wd steering box too, but thats a bolt on.
I the first thread I posted he swapped the front most crossmember b/c he needed it to make the truck 4wd when he was done. From the measurements I've done thats not needed just to make the blazer 2wd.
Edit: This is not a bolt in by any means. The crossmember has to be located, holes have to be drilled for it, engine mounts and the idler arm......
I should probably update that someday.. lol
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
