Old 01-24-2011, 10:46 PM   #1
JohnnyRocket
how low
just wondering how low i can go and fit a 22inch wheel under my 86 longbed. looking at doing a 2 1/2- 4inch drop
thanks
JohnnyRocket is offline   Reply With Quote
Old 01-24-2011, 11:22 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: how low
What size tires you going to run?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-25-2011, 09:53 PM   #3
JohnnyRocket
Re: how low
thanks for the response.. the tires i have are 265/35/22
Old 01-25-2011, 09:54 PM   #4
JohnnyRocket
Re: how low
i believe thats what they are...
Old 01-25-2011, 09:56 PM   #5
JohnnyRocket
Re: how low
heres a pic of how it sits now just wondering about rubbing issues i really want to drop this thing
Old 01-25-2011, 09:57 PM   #6
JohnnyRocket
Re: how low
Old 01-25-2011, 11:01 PM   #7
muthstryker
muthstryker's Avatar
Re: how low
Honestly, I would do a 4/6 Drop if I were you, you should be good. I dropped my friends truck, hes running a 265/40/22 tire its just about 31inches tall I did a 3/3 drop on it and its not low enough there is enough room up front on his truck to drop it another inch and not run into problems. The rear could also come down 3 more without a problem. Here are some pictures of his truck after we got done with it...
muthstryker is offline   Reply With Quote
Old 01-25-2011, 11:07 PM   #8
jojoman
Re: how low
yea i go with 4/6 a couple more inches and that truck would really look clean
jojoman is offline   Reply With Quote
Old 01-28-2011, 07:44 PM   #9
JohnnyRocket
Re: how low
thanks any where to get a good kit for a good price.. im looging at one in lmm for like $400.. and will i need a c-notch
Old 01-28-2011, 09:24 PM   #10
lilpoindexter
lilpoindexter's Avatar
Re: how low
What does the little hand in your back window mean?
lilpoindexter is offline   Reply With Quote
Old 01-30-2011, 09:17 PM   #11
JohnnyRocket
Re: how low
HAHA thats called the champion lol... Im a motorcycle stunt rider...
Old 01-30-2011, 09:18 PM   #12
JohnnyRocket
Re: how low
Old 01-30-2011, 11:57 PM   #13
Yupiamlo
Yupiamlo's Avatar
Re: how low
Im pretty sure a 265/35/22 has the same outside diameter as your stock 235/70/15 tires and I have a 5/5 drop on my 85, you can clear no problem. As far as the bolt in C Notch, You dont "need it" I drive mine without it in and you still have 3-4" of travel, but if you do put it in you won't ever hit
Yupiamlo is offline   Reply With Quote
Old 02-02-2011, 10:57 PM   #14
JohnnyRocket
Re: how low
thanks im slowly learning and liking my truck more and more... also wanted to add that i use my truck to haul my bike so it has 400+lbs in the bed all the time and for long distance on occasion... somtimes 800+ lbs when i take 2 bikes.. will this effect it..
Old 02-02-2011, 11:22 PM   #15
muthstryker
Re: how low
You could always add an airbag helper kit for the rear, that way you could still haul stuff and not have to worry about weight and the axle hitting the frame.
