Old 01-26-2011, 12:28 PM   #1
grs
Engine mount on frame. 6 cyl to V8
I can't fine ID numbers on the frame. It looks like the mount that bolts on the frame was moved forward. It is the mount that the engine mount bolts to. I believe it is covering the numbers up. Could the truck have had a 6 cyl. engine in it when new? Look at the picture. You can see another hole in the frame.
grs is offline   Reply With Quote
Old 01-26-2011, 01:02 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Engine mount on frame. 6 cyl to V8
There are 3 holes in the frame from the factory.
It could have had a 6-cylinder in it at one time,... but those are correct V-8 mounts in the correct location.
Keith
Convert to disc brakes.
Old 01-26-2011, 01:05 PM   #3
matthew20061
69' Chevy Stepside
matthew20061's Avatar
Check your vin number on your title or in the door jamb or glove box and see if it starts with CS then it was originally a 6 cylinder but if it starts with CE then it was a V8. The S stands for six and the E stands for eight. Hope that helps, on my truck the frame number is located somewhat in front of the frame engine mount so I don't think its covered up, I would check carefully it might be covered with paint.
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 01-26-2011, 01:13 PM   #4
grs
Thanks. The Vin number starts with a CE. For some reason my frame does not have numbers. And no sign of being ground off.
