Old 01-27-2011, 04:39 PM   #1
70chevymanshort
Question Firewalls
What is the difference between a 67 firewall and a 70 firewall?
70chevymanshort is offline   Reply With Quote
Old 01-27-2011, 05:19 PM   #2
Jeffs70
Jeffs70's Avatar
Re: Firewalls
I don't believe there is any difference but I could be wrong.
Jeffs70 is offline   Reply With Quote
Old 01-27-2011, 05:40 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Firewalls
the location of the parking brake cable coming through, and the way the fuse box/wire bulk head mounts.
Otherwise, they should be pretty much the same
Old 01-27-2011, 05:50 PM   #4
70chevymanshort
Re: Firewalls
Can I install a 70 firewall on a 67 cab then?
Old 01-27-2011, 05:56 PM   #5
70chevymanshort
Re: Firewalls
I want the parking brake off a 70 truck in my 67 truck.
Old 01-27-2011, 08:03 PM   #6
67chevy1series
67chevy1series's Avatar
Re: Firewalls
personally i like the the hand brake because it goes in the way of your leg room so it makes you release it my dads 70 ,he drove to my school picked me up and went home and then noticed his e brake was on .....
67chevy1series is offline   Reply With Quote
Old 01-27-2011, 09:10 PM   #7
chewychevy67
Re: Firewalls
they are stamped a little different in 67 than 68-72s as well next to the a/c heater box right by the dip for the engine. i heard they changed this in 68 to make more room in the engine bay for a big block. blue pic is of 67 and cut out is 68-72.
chewychevy67 is offline   Reply With Quote
Old 01-27-2011, 10:22 PM   #8
70chevymanshort
Re: Firewalls
So my question is, can I put a 70 firewall on my 67 cab? Will it work and line up with the flanges?
Old 01-28-2011, 02:51 AM   #9
matthew20061
69' Chevy Stepside
matthew20061's Avatar
Re: Firewalls
I would think the flanges should be exactly the same but I've never done it so I can't say for sure.... I would think they are the same as these trucks share just about everything almost from year to year.
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
