Old 01-28-2011, 12:13 AM   #1
rynehbar
Another Fuel wire question
Heys guys new to the forum and linking up with you from Fort Dodge,IA currently the Marine Recruiter here. But anyways while being here in Iowa I picked up a 67 C10 LWB with a 250 I6 for $400. And noticed right away while driving her home that the fuel gauge didn't work. Well i guess this is a huge problem with this year model trucks after doing some research. But my question is after tracking down the problem is, Where does the wire hook up to in the motor bay? It's currently just hanging by the starter but theres no connection close to that so I don't know and trying to follow schematics on it is like trying to find jimmy hoffa. Any help would be greatly apperciated. And HELLO FROM FORT DODGE IOWA.
rynehbar is offline   Reply With Quote
Old 01-28-2011, 01:02 AM   #2
dmack91
dmack91's Avatar
Re: Another Fuel wire question
Shouldn't be anything in the engine bay. The sending unit wire hooks into a plug in the fuse box that is labeled.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 01-28-2011, 11:30 AM   #3
rynehbar
Thanks for the post and the sending unit wire is hooked up to the fuse panel box that is labeled as fuel but that hook up is not getting power and following the wire to the engine bay it's not hooked up so again thanks for the post but still dosen't fix my problem.
Old 01-28-2011, 11:36 AM   #4
Shyguy
Junior Member
Shyguy's Avatar
It sounds like some one ran the wire you are describing for a reason other than gas tank level.
The gas tank sending unit wire goes from the fuse panel to the sending unit at the tank along the driver's side step plate on top of the rocker.
The sending unit wire gets power from the ignition through the fuse panel.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 01-28-2011, 11:51 AM   #5
rynehbar
Awesome so i should be looking for a wire from the ignition to the fuse panel then. Thanks for the help will try to go that route and let you guys know.
