Closed Thread
Old 01-29-2011, 12:08 AM   #1501
Jeffs70
Jeffs70's Avatar
Re: What did you do to your truck today!
created a mold for my center console to begin fiberglassing the shape. and got closer to finishing my radiator/core support cover
Jeffs70 is offline
Old 01-29-2011, 12:21 AM   #1502
project 67 sub
project 67 sub's Avatar
painted around the windshiel area inside and out, finished painting the splash pan, painted the radiator core support, radiator, frame rails, also painted the drivers side fender. i also installed the grille trim and started installing the grille. also purchased some headlight and wiper switch knobs and bezels from sharpie
project 67 sub is offline
Old 01-29-2011, 12:21 AM   #1503
project 67 sub
oh, and i sprayed some rust reformer paint on the inside of the replacment passanger fender
Old 01-29-2011, 09:55 PM   #1504
kpeztruck
kpeztruck's Avatar
Washed it, then drove it all over town. Here it is at the local parts store parking lot. Had to stop, running a special on brake cleaner.
kpeztruck is offline
Old 01-29-2011, 10:18 PM   #1505
wwotr
wwotr's Avatar
AWESOME!!!!!!!!!!!!!
Hello members...
I'd like you to know that I sold,
my 72 GMC (Ratikle),
back in November of 2011.
I don't visit the site much anymore,
but please feel free,
to drop me a private message.
RIP...."RATIKLE"
wwotr is offline
Old 01-29-2011, 11:16 PM   #1506
67Slider
67Slider's Avatar
Bought new front drop springs from CPP! My youngest son was inspired to do his pinewood derby car from one of the posts on here. He is making his a truck!
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 01-29-2011, 11:25 PM   #1507
Sicklajoie
The Niner
Sicklajoie's Avatar
Fixed an oil leak, changed the oil, filled the gas tank, took her to the car wash, then put her back in the garage until the snow melts (July I imagine...)
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline
Old 01-29-2011, 11:47 PM   #1508
glider_6969
I put the correct pitman arm on my power steering box and mounted it on the truck, maybe tomorrow I'll get pump mounted on the motor,
glider_6969 is offline
Old 01-29-2011, 11:51 PM   #1509
Sonicman
Sonicman's Avatar
Do you have a side pic of your truck? I would like to see your wheels. My 69 is almost identical to yours minus the upper body trim. Could looking ride. Here in TX it was 70 today!!!!
Sonicman is offline
Old 01-29-2011, 11:58 PM   #1510
Sicklajoie
The Niner
Sicklajoie's Avatar
They're Alcoa aluminums. I guess they don't make that style anymore but I've seen some on Ebay.
Old 01-30-2011, 12:17 AM   #1511
project 67 sub
installed the door hinge that i got from sharpie, notched my dash mount, welded some studs to the bottom of the dash, and installed and painted the dash (will do body work on the center later), also aquired some new mirrors for my burb
Old 01-30-2011, 12:18 AM   #1512
project 67 sub
Old 01-30-2011, 12:46 AM   #1513
'72customdeluxe
adjusted my detent cable. Rolling one tire fires and no more manually shifting at wot
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline
Old 01-30-2011, 02:14 AM   #1514
vectorit
What?
vectorit's Avatar
fixed my rear upper shock mount, then took her out for ride to another board members hacienda for a visit.
Nice day.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline
Old 01-30-2011, 02:40 AM   #1515
67chevy1series
67chevy1series's Avatar
got parts for it and cool things that arent parts for it more like presents! ad painted them
67chevy1series is offline
Old 01-30-2011, 01:29 PM   #1516
re1
re1's Avatar
Found a nice takeoff tailgate for my truck,
to bad its the wrong colour.
1972 Chevy C10 Custom Deluxe Highlander
1972 Chevy C10 Custom Deluxe Medium Green
re1 is offline
Old 01-30-2011, 05:00 PM   #1517
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Nasty day around here today. Yesterday was beautiful, but a bad day for the wrenching. As I was installing and trying to adjust the linkage on the T350,
I found out the steering column I'd painted and otherwise massaged is full of enough slop as to not let "Park" be "Park"....
I was able to make a radio block off for the newly painted dash. I made it out of a radio...I just applied a liberal amount of grinder with a cut-off blade and
a half a garbage can worth of '68 radio internals. I'm thinking about making a little plaque that will match the ignition indicator. It will say, "This Radio Does Not Work".
Even though it was a nice weather day yesterday that, by the end of the day had me pissed at more need for part$ I didn't count on (what's new about that?),
today working in the the nasty weather day yielded some good results. Adjusted the ECE adjustable pan hard bar (I have about 3/8" equally between the inside of the wheel tub and the tires riding on 20 x 10's),
and tightened down the rest of the rear suspension parts.
Installed the rear roll pan, and mounted the passenger door.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 01-30-2011, 05:12 PM   #1518
Blue Rat
I put an new alternator on mine today.
Blue Rat is offline
Old 01-30-2011, 06:30 PM   #1519
(joey)
(joey)'s Avatar
continued with the body drop.finished the last couple peices of the floor supports then started some sheet metal
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain)
http://67-72chevytrucks.com/vboard/s...d.php?t=434253
(joey) is offline
Old 01-30-2011, 06:57 PM   #1520
quentin hill
quentin hill's Avatar
Finished my bed
"TO GO AN EXTRA MILE AND PERFORM MORE THAN WHAT ONE IS COMPENSATED FOR"
quentin hill is offline
Old 01-30-2011, 07:30 PM   #1521
Kidd-7
Kidd-7's Avatar
That is sweeeeeeeeeeeeeeeeeet; I never though of going 1 piece...
Kidd-7 is offline
Old 01-30-2011, 07:42 PM   #1522
steelscout
Words under my name
steelscout's Avatar
I took both doors apart, replaced one door handle, I was going to replace window regulator but decided not yet because I need to get new weather trim first, Pulled both door locks out, I am going to either get new ones or get these re-keyed. Installed new window visors. Took her for a ride, on the freeway, I need to get her timed, she was making a poping noise when I pushed in gas peddle when I was at around 65 mph. I bought a compression tester and timing light, I was going to do the checks but my lady needed me, so I will continue next weekend.
69 Chevy CST/10 "Project: Bloody Knuckles" my slow going project.
2010 VW Golf, daily driver
Wrench Rookie
steelscout is offline
Old 01-30-2011, 08:38 PM   #1523
rick0312
rick0312's Avatar
place some insulation purchased from Lowes 16 bucks did the cab floor and plenty leftover
69 C10 LWB GM 350 crate motor, 3.73 rearend
rick0312 is offline
Old 01-30-2011, 11:00 PM   #1524
Bowtie1216
Bowtie1216's Avatar
Replaced my rear u-joint in the ol' '72
1972 Chevy C/10 Custom Deluxe
1973 Chevy C/10 Custom Deluxe
Bowties for life
Bowtie1216 is offline
Old 01-30-2011, 11:11 PM   #1525
kpeztruck
kpeztruck's Avatar
Thanks, at least the local police still think it is cool, as long as I don't do anything stupid. Difficult with a 15.5:1 540 BBC, but I managed to stay out of trouble.
Closed Thread
