Old 01-27-2011, 02:10 PM   #1
dukes69
Junior Member
205 transfer case to 4L80E
Will a 205 bolt to a 4L80E? If not the 205 is behind a 4spd now, is there a special adaptor to work with a th400? I am thinking of building a 94-98 c2500 to 4wd using a 79 K20 as a donor (using the tranfer case and front end)
1968 chevelle ss 396 4spd
1969 chevy 4wd 350 4spd
1970 chevy c10 long box
1970 GMC 4wd long box
dukes69 is offline   Reply With Quote
Old 01-27-2011, 10:45 PM   #2
john@thepier
john@thepier's Avatar
Re: 205 transfer case to 4L80E
The best place I have seen for adapters is a place called ADVANCED ADAPTERS they sell many types of adapter and conversion kits. Good luck
john@thepier is offline   Reply With Quote
Old 01-27-2011, 11:29 PM   #3
1959 Apache
The 4L80E has the same output shaft splines and 6 bolt adapter pattern as a TH400. So if you can find an NP205 that was originally mated to a TH400, Then the adapter and input shaft will fit on the 4L80E.
Dave W.
1959 Apache is offline   Reply With Quote
Old 01-29-2011, 03:44 PM   #4
Aegeas
Correct me if I'm wrong, but isn't the 4L80E longer than the TH400?
Aegeas is offline   Reply With Quote
Old 01-29-2011, 03:51 PM   #5
67swb72klb
67swb72klb's Avatar
1.5 inches move eng foward
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 01-29-2011, 05:22 PM   #6
1959 Apache
Yes it is, The 4L80E is 4 speed electronic version of the TH400 (3L80).
Dave W.
Old 01-29-2011, 05:28 PM   #7
Aegeas
So to put a 4l80E in a 70-87 4x4 model you pretty much have to move the transfer case and transmission mount back about 1.5 inches plus buy the electronic transmission controller too. Seems like a pricey and difficult task to me.
