Closed Thread
Old 01-29-2011, 03:52 PM   #2476
scum1
scum1's Avatar
Re: What did you do to your truck today?
nice score! now put the old hood on the clip and make a bad ass bbq!!
scum1 is offline
Old 01-29-2011, 07:03 PM   #2477
kirtzen
kirtzen's Avatar
Originally Posted by alwaysbroken View Post
put a new steering column in my street truck and ordered a body lift a few days ago. should be in tomorrow in by this weekend.
Where did you find a body lift? Will it work on a 3/4 ton?
kirtzen is offline
Old 01-29-2011, 07:44 PM   #2478
70inline6
Disassembeled my carb and put the little pieces in a can of carb cleaner. Will take pics and post rebuild results tomorrow.
70inline6 is offline
Old 01-29-2011, 10:53 PM   #2479
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Finally got my clutch pedal assembly to work right on my 62, now if it'll only last I might be able to replace the clutch, bleed the brakes and work on the heater fan assembly, I could be driving it!
The foot of snow on the cab and foot and a half above the bed rails adds weight for traction. If only it wasn't supposed to be -18 tonight......
Ghostwhite is offline
Old 01-29-2011, 11:53 PM   #2480
Daddy64
Weather was nice here today so I took it out for a little ride. Been in the barn since December.
Daddy64 is offline
Old 01-29-2011, 11:54 PM   #2481
cb1965
cb1965's Avatar
put in new power steering hoses & pump . thermostat. upper radiator hose. and drove the hell out of it for the first time in a while
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline
Old 01-29-2011, 11:59 PM   #2482
k1rodeoboater
Sadly nothing today...but I did get to do quite a bit of research into doing a disc brake conversion for my 66, as well as compile a list of parts I need to order. I'm going to pick up my donor parts from my storage unit tomorrow, break them apart, and start cleaning them up.
the good idea fairy also paid me a visit today...and I figured out how I can have a bed mounted tool box in a stepside bed. The bed is 50" wide and I found a metal box that is 48" wide. Is it ghetto...yeah kinda...but hey I need storage for my tools and it'll be a lot tougher for someone to break into this than a plastic locking tote box.
They make a 36" one too that's about half as small...but it's so small I can't see a good use for it after I'm done with it. The 48" one I can at least use as a secure storage cabinet for my ammo, gunpowder, and primers as well as my many misc gun parts, parts guns, and stuff from when I had my own gunsmithing business.
worst case it'll become my zombie apocalypse safe box kinda like this http://www.ar15.com/forums/topic.htm...=304121&page=1
Page 4 of that thread has the plastic locking tote I was thinking about getting. They're similar to the tuff boxes we get for deployments...they're not that "tough". And it's a lot easier to break through plastic than metal
k1rodeoboater is offline
Old 01-30-2011, 05:08 PM   #2483
kirtzen
kirtzen's Avatar
I replaced the starter.
I changed the oil.
kirtzen is offline
Old 01-30-2011, 06:40 PM   #2484
jbgroby
jbgroby's Avatar
Got the painting on the cab finished!!!
jbgroby is offline
Old 01-30-2011, 06:59 PM   #2485
knuckledragger
knuckledragger's Avatar
Finished the steering column install,bled the brakes, started the pipe notch.Put the spring retainers in.
65 c-10 swb,bbw,step,402/t350,sold!!
1979 c10 Silverado,250,auto,gonna have a 3/5 drop,and twice pipes!Sold
Bought the wife a 84 gmc short step
knuckledragger is offline
Old 01-30-2011, 07:06 PM   #2486
lakeroadster
jbgroby that paint is beautiful!
I got my 3rd brake light installed and installed my seat brackets and seats for what I truly hope is the last time for quite a while.
See post #39 of this link for more data on the 3rd brake light: http://67-72chevytrucks.com/vboard/s...=437302&page=2
lakeroadster is offline
Old 01-30-2011, 07:52 PM   #2487
65Gregg
65Gregg's Avatar
Smile Re: What did you do to your truck today?
Started taking everything loose in preperation to pull the engine. About the only thing left is the hood,fuel line, trans cooler line, headers & distributer. I work slow so this ought to be done in another year...
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline
Old 01-30-2011, 09:36 PM   #2488
64GMCHorsepower
Justified!
I installed my 2 new engine mounts, and the adjusted my new roller rockers.....
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline
Old 01-30-2011, 10:34 PM   #2489
Chevy Fleetside
Chevy Fleetside's Avatar
I got the fuse box mounted and some new holes drilled in the firewall to run new wires to where I want them. I am using an EZ Wiring harness with 21 circuts. Man there are alot of wires.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 01-30-2011, 11:35 PM   #2490
kiknrocks
65 Chevy
kiknrocks's Avatar
Just finshed installing My power steering setup with the CPP kit and rebuilding my colum. Works great
side note; That cpp stuff is nice!
kiknrocks is offline
Old 01-31-2011, 12:42 AM   #2491
kalirodding
CLASSIX Truck Club
kalirodding's Avatar
Originally Posted by kiknrocks View Post
Just finished installing My power steering setup with the CPP kit and rebuilding my column. Works great
I don't believe you. I'm gonna need some pics for proof.
kalirodding is offline
Old 01-31-2011, 12:53 AM   #2492
tenni126
Ended up having to go into work for a few hours. My plan was to watch the end of the 24 hours at Daytona race and nurse my hangover, but no such luck. Still, got some stuff done.
-Replaced the blower motor for the heater
-Finished mounting the 3-point retractable belts on the driver side
-Replaced the fuel filler hose. Finally, I can fill it up all the way. Why did I put up with that for 15 years?
-Started replacing the felt strips/rattle strips on the driver's side. Stopped by the rain, had to stick a wood shim in there to keep the window up for the night.
And, finally got off my a@# and cleaned up the garage a bit.
*If anyone's looking for parts, I have the stock 6-lug wheels, drums, spindles, master cylinder, and stock height springs I'd like to offload, just PM me.
tenni126 is offline
Old 01-31-2011, 01:01 AM   #2493
kiknrocks
65 Chevy
kiknrocks's Avatar
Hahaha.... I only took some pics of it finieshed cuz I forgot about progress
pics. Ill post some later
Old 01-31-2011, 05:51 AM   #2494
old cruiser
old cruiser's Avatar
Got my road worthy cert today and booked in with Vic roads to be registered on thursday hope all goes well
old cruiser is offline
Old 01-31-2011, 10:23 AM   #2495
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
The demo has begun on the cab. Its just about all stripped down and getting it ready for paint. I have two weeks to finish everything before paint.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline
Old 01-31-2011, 10:58 AM   #2496
jbgroby
jbgroby's Avatar
Strange trans hump. Never seen that before. I remember those days, it did not seem so long ago that I was right where you are. You exicted yet? OH and how many hours have you are going to spend dreaming on all the goodie's you're going to do.
jbgroby is offline
Old 01-31-2011, 11:02 AM   #2497
61_FL_Apache
Who Me?
Oh yea, im excited!! I have more sheet metal work to do this week to get ready... The outside had been done for a while now, now its the cab's turn. Next is the engine bay.
Steve
2001 Blazer 4D 2WD
Old 01-31-2011, 09:49 PM   #2498
towersddg9
towersddg9's Avatar
patched up some holes in the cab, gas inlet and filled some holes under the dash, got to cut out the PO hammer work for HEI clearance next, the cab had those two holes at the bottom that I have seen on these trucks for the dealer installed air, planning on putting in AC vents in the ashtray area sorta like the OE version but will make my own.
towersddg9 is offline
Old 01-31-2011, 09:56 PM   #2499
knuckledragger
Tinkered a little after work and bent the trans cooler lines and the fuel line to the carberator.
Old 01-31-2011, 11:17 PM   #2500
markeb01
Senior Enthusiast
markeb01's Avatar
I really like the custom filler panel on the cowl. I've never seen that done before. Nice work.
markeb01 is offline
Closed Thread
